Fuse Panel question
Started by mcain, July 26, 2017, 01:16:07 PM
mcain
I have a 1957 series 62  - does anyone have a picture of how the fuse panel behind the floor speaker is secured?  it was floating around when I purchased the car and trying to figure out how/what it attaches to?
thanks in advance
Matt
I know I took mine out of the '58, which is the same, to inspect the backside for corrosion and think it was just (2) sheet metal screwed in.   It was on top of a fiber backed insulation piece also.
If it's floating around either the screws are missing, rotted floor/kickpanel, or missing insulation.   It's described in the shop manual, if you have one.
The fuse blocs from this area is rather primitive. At the back, there are 2 flanges which are inserted into the firewall insulation. No screw, just that primitive method. Even the expensive '57 Brougham has this system.
When I replaced the car's wiring, I did no picture from the back, just from the front. Your fuse block is looking more or less the same.
Quote from: fishnjim on July 27, 2017, 08:30:10 PM
I believe that the fuse panel was changed for 1958; it is less archaic than before.
mcain
thanks very much to both!!
Cadillac Jack 82
Quick question regarding fuses.  My radio powers on but I don't get a signal.  It worked fine about 3 weeks ago.  Is this a fuse issue or a power unit issue?
Tim
CLC Member #30850
1959 Cadillac CDV "Shelley"
1964 Cadillac SDV "Rosalie"
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1955 Packard Clipper
1957 Cadillac Series 62
1962 VW Bug
1962 Dodge 880
1966 Mercury Montclair
1968 Chevy Chevelle SS
1968 Plymouth Barracuda
1977 Lincoln MKV
