Negitive ground cable
Started by Tpicks55, July 27, 2017, 09:11:58 AM
Tpicks55
My 75 Eldorado has the negative ground cable bolted to the right fender and the cable is about 12 inches.  That doesn't look right as I think it should go down to the frame.  It works this way but I'd like it the right way it should be.  I'm asking for your expertise on this matter with a thanks in advance.
75 Eldorado Convertible
94 Deville Concurs
2019 Lincoln Continental
2016 Cadillac XTS
I'm pretty sure its supposed to go to the frame pretty much directly below the batter.    There is then a braided cable between the frame and engine near the starter which is on the same side in the Eldo.
Tpicks55
Thank you guys thats what I suspected but wasn't sure and its not clear in the manual.
94 Deville Concurs
2016 Cadillac XTS
CadillacRob
The more grounds the merrier.  I have one to my engine, fender and frame.
1950 series 61 sedan
1956 coupe de ville
Cadillacs had lots of grounds.
Exhaust to body, front wheel grease caps to stub axle, and a lot more that are hidden.
A long time ago I ran another from that connection point on the frame to the alternator bracket just to be sure I had a good connection.
Tpicks55
thanks all good suggestions :D
94 Deville Concurs
2016 Cadillac XTS
