1957 Wonderbar Tube/Vibrator part numbers?
Started by Cadillac Jack 82, August 02, 2017, 01:17:01 PM
Cadillac Jack 82
Does anyone have the correct tube/vibrator list for the 1957 Cadillac Wonderbar radio?  Thanks!
Tim
Tim
CLC Member #30850
1959 Cadillac CDV "Shelley"
1964 Cadillac SDV "Rosalie"
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1955 Packard Clipper
1957 Cadillac Series 62
1962 VW Bug
1962 Dodge 880
1966 Mercury Montclair
1968 Chevy Chevelle SS
1968 Plymouth Barracuda
1977 Lincoln MKV
J. Gomez
Quote from: 57shark82 on August 02, 2017, 01:17:01 PM
Tim
Tim,
FYI
J. Gomez
CLC #23082
Cadillac Jack 82
Thanks I found a vibrator on Ebay.  I just need to identify the tube numbers/types.  Do you have that list?
Tim
CLC Member #30850
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1962 VW Bug
1962 Dodge 880
1977 Lincoln MKV
J. Gomez
#3
Quote from: 57shark82 on August 02, 2017, 02:16:33 PM
8 Tubes: 12BA6 12BE6 12BA6 12BF6 12AU7 6V6GT 6V6GT 0Z4
If your is the 725 8065
HTH
J. Gomez
CLC #23082
Chances are most if not all the tubes are serviceable; the vibrator and the
0Z4 rectifier are the common failures.  After that think about ancient, leaky
capacitors.  Bruce Roe
Isn't the OZ4 one of the ones you can get a plug in solid state replacement for?     In the stuff I used to work on the rectifiers hardly ever had issues but my stuff ran on line voltage so the overall power supply design was likely different than mobile stuff.
Quote from: TJ Hopland
Without a heated cathode the 0Z4 simplified the battery rectifier problem,
but it had a shorter life.  A couple silicon diodes can do the same thing, if
chosen for that hostile environment.  Probably someone makes it.  Bruce Roe
I didn't notice they were cold cathode.  That should make em easier to convert to a diode because you don't have to account for the lack of heater load.  Harsh environment meaning voltages?   That is one nice thing about everything being switchers these days,  plenty of high voltage components available again.
#8
Quote from: TJ HoplandI didn't notice they were cold cathode.  That should make em easier to convert to a diode because you don't have to account for the lack of heater load.  Harsh environment meaning voltages?  That is one nice thing about everything being switchers these days, plenty of high voltage components available again.
From the original tubes with directly heated filament/cathodes, ground
was established as the negative terminal of the circuit.  With AC you
could use a pair of diode tubes for a full wave rectifier, or one tube with
2 plates.  The latter was chosen, but its cathode must be at the positive
plate potential.  So if directly heated, the filament can't be at ground;
this was solved on AC radios by a special (5V) winding on the power
transformer for the rectifier.
The above was very undesireable when the AC had to be generated
by a limited capacity vibrator.  Some car radios used a 6X5 type of
tube with indirectly heated cathode; these would tolerate full plate
voltage between the filament and cathode.  Another attempt was
the synchronous 6 pin vibrator, using a second set of contacts to
connect the transformer secondary when the correct voltage was
present.
The 0Z4 solved the problem and reduced the power consumed by
the battery powered radio.  But it had a somewhat shorter life.
The silicon diode appears to be a drop in replacement.  But
diodes have a specific limited reverse voltage, to avoid destruction.
The vibrator power supply, like your ignition, has at least the
possibility of generating some extremely high voltage spikes.
These spikes may be extremely short, tubes tolerate them, but
diodes don't.  To help with this there is the "buffer" cap already
used on the transformer secondary.  If this cap fails, it may take
the diodes with it.  Bruce Roe
Cadillac Jack 82
#9
So I've started testing my radio to see what the issue is.  The first thing I did was remove the old fuse that was in the connector.  It turns out some idiot modified the old 7.5 amp fuse with a piece of copper.  When I added a new 7.5 fuse it popped.  I added another and it popped.  I assume that the vibrator is causing the fuses to pop?  Should I just remove the unit and have it rebuilt?
Tim
CLC Member #30850
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1962 VW Bug
1962 Dodge 880
1977 Lincoln MKV
Start by pulling the vibrator and seeing if the fuse holds.  It would be best
to use an adjustable battery eliminator with meters to check drain.  If the
fuse still blows, something is shorted in the 12V circuitry; should not be
hard to fix.  If the drain drops way back, I'd replace the transformer
secondary buffer cap, put in a replacement vibrator, and try again without
the 0Z4.  If that works but putting in the 0Z4 blows the fuse, you probably
have a short in the 200V B+ circuitry, typically a cap.  Any radio that age
is ready for all new replacement caps anyway, not very expensive if you
supply the labor.  Bruce Roe
J. Gomez
Quote from: 57shark82 on August 04, 2017, 11:56:34 AM
Agree with Bruce's comments, the +12V from the fuse is feed to the power transformer to energize the vibrator. If the contacts are welded together (which most are due to arching) it will blow the fuse.
The rest would be up to a specialist to care for if you are not into electronics.  ;)
Good luck..!
J. Gomez
CLC #23082
Walter Youshock
That is not good.  A new solid state vibrator MAY fix it but that and throwing tubes at it is not going to solve the problem of dried out capacitors.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
