1976 Fleetwood Theft Deterrent System
Started by fellenzer, August 19, 2017, 02:44:19 PM
fellenzer
Hi,
Recently acquired a '76 Fleetwood with Theft Deterrent System that isn't working. After reading the service manual, it is unclear to me where the two inline fuses are located. Should I be able to see them without removing any dash components?
This is a 28K car. Generally in very nice overall condition. Well optioned including EFI and ACRS.
Equipped with Illuminated Entry and Fuel Economy Monitor, both also not working. AC working; however, climate controls not working. Nothing happens when changing temperature and air only blows to the floor.
Thanks.
Michael Fellenzer, #30007
Indianapolis, IN
1976 Eldorado Convertible
1976 Fleetwood Sixty Special Brougham (EFI, ACRS)
1976 Coupe deVille (Astro/Cabriolet)
1984 Seville
1989 Fleetwood Coupe
1989 Sedan deVille
1992 Fleetwood
1992 Coupe deVille
1992 Sedan deVille
1993 Sixty Special (Ultra)
1994 Fleetwood Brougham
2015 SRX
D.Smith
Huh.  Seems odd for there to be more than one fuse out on such a low mileage car. Especially the inline one(s)    Could there be a bad ground?    Check the book to see where the major underdash grounding points are.  With so many things inop I'll bet you that there is a ground not secure.    Those upper panel dash warning lights (fuel monitor and alarm warning lamp included) have power to them and work when grounded.
Also,   We must see some photos of that car!   ACRS!  oh my!
fellenzer
Thanks. I was wondering about ground or a common fuse. Being very cautious about doing anything in the dash as the last thing I want is a 41-year-old airbag going off in my face. I need to find the service manual supplement for ACRS. I have the standard set of manuals for '76.
Here are pix:
https://www.facebook.com/media/set/?set=a.1687841621228960.1073741856.100000094163147&type=1&l=1bc5ed6abb
Indianapolis, IN
1984 Seville
1989 Sedan deVille
1992 Fleetwood
1992 Coupe deVille
1992 Sedan deVille
2015 SRX
joecaristo
Hi,
You have to remove the lower dash section to see the inline fuses to the Security System.
Joe
Joe Caristo
fellenzer
Thanks. What do I need to look out for with the ACRS system? Is removing that fuse enough?
Indianapolis, IN
1984 Seville
1989 Sedan deVille
1992 Fleetwood
1992 Coupe deVille
1992 Sedan deVille
2015 SRX
