1959 Cadillac - Replacement Interior Light Sockets?
Started by Dan Eckstein, August 20, 2017, 03:41:35 PM
Dan Eckstein
Hello,
Does anyone know where I can buy replacement interior light sockets that fit a 59 Cadillac?
Thank you for your time,
Dan Eckstein
CLC #24850
gene harl
Try Ken Perry.... he would have them.....
  Gene Harl    CLC22406
Dan Eckstein
Any ideas on where to buy the little copper crimp connector inside the socket?
Dan Eckstein
CLC #24850
J. Gomez
Dan,
You could re-use your existing ones, you drill out the crimped wire inside and re-solder the new one in. I do not trust the crimp by itself, I’ve always prefer to solder all my connections instead.   ;)
Or you can find the brass contacts here - > http://www.superbrightbulbs.com/connectors.htm
Good luck..!
J. Gomez
CLC #23082
I used to have plenty of trouble with the center bulb knobs maintaining
contact: the socket spring had relaxed.  I used some solder to build up
the bump on the bulb 1/32" or more, and the problem vanished.  Bruce Roe
59-in-pieces
Dan,
Frugal Freddie here - what is that all about.
Have you tried soaking the sockets in CLR (Calcium Lime Rust) remover-cleaner.
Wiping the brass ends of the bulbs works best - rather than submerging them to soak.
Just a thought.
Have fun,
Steve B.
S. Butcher
