1939 Cadillac LaSalle Parts
Started by 39LaSalleCaddad, August 21, 2017, 11:27:17 AM
39LaSalleCaddad
I recently purchased a 1939 Cadillac Lasalle.  Major issues with the starting circuit.  NOS is either non existent or out of my price range.  Can anyone assist with finding replacement part equivalents, etc. so I can keep this car on the road?
You don't say what parts you require??
Barry M Wheeler #2189
If your problem is with the solenoid, you can carefully take it apart and reverse the round copper disc to get an un-pitted surface. (You may have to buff it with wet'n'dry paper to brighten it up.) Be careful not to break the Bakelite pieces that hold the connecting bolts to the "outside." Clean everything up and get a kit with new bushings and brushes as well.
When you remove the starter, either find a curved 5/8"-3/4" starter wrench or do what I did, simply cut that sized boxed end wrench in half so you are not fighting the extra length that you don't need to remove the 5/8" bolts. (When you go to put it back in, find two shorter bolts :Maybe 1 1/8" in long and clean them so you can insert them with a socket and extension finger tight.) You also need to find some braided double end starter cable and bolt one end to the lower starter bolt and the other to the rear transmission support where it bolts to the "X" of the frame. You need a lot of ground for this engine.
Others will probably chime in with additional suggestions or corrections as I am working from memory. Good luck.
Barry M. Wheeler #2189
1981 Cadillac Seville
1991 Cadillac Seville
Give us some more info.
If you want to change to a new, corvette, solenoid that is do able but there are consequences.
jw
John Washburn
CLC #1067
1937 LaSalle Coupe
1949 62 Series 4 Door
1949 60 Special Fleetwood
1953 Coupe DeVille
1956 Coupe DeVille
39LaSalleCaddad
Thanks fellas for the assistance.  Starter circuit is solid now.  Yes a lot of ground indeed!
Radiator pulled for leaks; Needs new core - local shop quote $1,000.  Unless there is an aftermarket radiator you can recommend I may be into the wrong car :(
It's 100% original.  I'm really hesitating to start swapping pieces out.  However, it may be the only way I can drive it.  Can anyone recommend a good aftermarket radiator?  If not, I have an all original 4 door 39 la salle I might be willing to sell in really good original condition minus a couple problems to someone with the checkbook to handle it.
I'd rather keep it though!
tturley
Member # 28929
1940 Lasalle model 5019
1995 Ford F-150
2015 Buick Enclave
39LaSalleCaddad
You should be able to take it to a good radiator shop and they can re-core the old girl. If they can do that for my 37 LaSalle I have to believe they can do it for your 39.
Also look in Hemmings they have listing for vendors who deal in nothing but radiators. Don't give up hope yet and remember this is just a hobby.
The Johnny
John Washburn
CLC #1067
1937 LaSalle Coupe
1953 Coupe DeVille
1956 Coupe DeVille
39LaSalleCaddad
Thanks John. Quote to recore was 1k. Have one more shop to try.
Thanks for the feedback. It's a great hobby for sure!
tturley
Does a 40 use the same radiator as a 39 ?
Member # 28929
1995 Ford F-150
2015 Buick Enclave
Glen
Does this help?
Glen Houlton CLC #727
CLCMRC benefactor #104
39LaSalleCaddad
tturley
I asked because I have a good one for a 1940
Member # 28929
1995 Ford F-150
2015 Buick Enclave
39LaSalleCaddad
tturley
I think that the parts list that Glen posted shows that they are different.
Member # 28929
1995 Ford F-150
2015 Buick Enclave
