Headlight switch vacuum hose order?
Started by 67_Eldo, September 08, 2017, 08:00:58 PM
67_Eldo
I was too much of a hurry when I removed the headlight switch from my 67 Eldorado. I figured I'd always remember the order in which the vacuum hoses were arranged.
I forgot.
Looking at the low-res shop manual, I *think* the order of the color-coded hoses was red (at the farthest end of the switch, closest to the firewall), green, and yellow (closest to the dashboard bezel).
At the moment, I don't have a hose that would go in the yellow position, but I'll find its rightful connection someday! :-)
I've attached a diagram that indicates how I *think* the hoses should be connected.
Am I wrong?
Thanks!
Glen
According to my notes the red hose goes to close the doors, green to open and yellow is the vacuum supply.  With that in mind your drawing looks to be correct.
Glen Houlton CLC #727
CLCMRC benefactor #104
67_Eldo
