2002 DTS intermittent air cond/heat problem, intermittent.
Started by TonyZappone #2624, October 15, 2017, 06:55:37 PM
TonyZappone #2624
took 600 mile trip thurs and fri.  with 2002 DTS 110,000 miles car that appears and functions as new otherwise.  Blower and aircondiioner comes on when it feels like it, or tonite it came on when I hit a bump.  Any ideas?
Tony Zappone, #2624
1936 Pierce-Arrow conv sed
1947 Cadillac Conv cpe
1958 Cadillac conv
2016 Cadillac CT6 Platinum
Hi, Tony, Dave Shepherd here, first I would try and check for any related TSB's, Sounds like a main input is loose or not making good contact.  Remember that system is controlled by the bcm. You need a starting point here, like a wiring diagram and or trouble tree chart.
TonyZappone #2624
Thank you David.  I  will take it to my local shop tomorrow, and have them do the diagnostic plug in?
Tony Zappone, #2624
1958 Cadillac conv
TonyZappone #2624
The problem with the intermittent heater/AC function was  worn out connector ends on the blower motor.  Luckily, unit was  inop when I brought it in, and the wiggling movement at the ends provided a fairly rapid diagnosis and fix.
Tony Zappone, #2624
1958 Cadillac conv
