1940 Lasalle Model 52 Battery Cable Routing
Started by tripwire, October 18, 2017, 10:27:52 AM
tripwire
Hello,
Before I put my car up on jackstands to replace the negative battery cable (from battery to starter) can anyone tell me how and where this cable is routed under the car?  Are there brackets holding the cable along the way?  If not, should there be brackets?
Or, can I just use the old cable as a fish tape and pull the new cable through?  Any ideas would be appreciated.
WParo in VT
Driving now:
2023 XT4 Luxury
1940 LaSalle 5229 C4D
A few I used to drive:
1976 Cadillac Ambulance
1969 Cadillac Hearse, Superior Body
1966 Buick Wildcat Hearse
1957 Ford Thunderbird x 3, 1 E code, 2 D code
1956 Oldsmobile Rocket 88 Sedan
1949 Mercury Convertible
1949 Mercury Coupe, Mild Custom
1936 Buick Special Sedan
tturley
Replace cables on my 40 Lasalle and did not need to fish them. There were heavy wires that are looped on the ends connected to motor that wires go through.
When you get it up where you can see it t
Member # 28929
1940 Lasalle model 5019
2011 Escalade platinum Edition
1995 Ford F-150
2015 Buick Enclave
tturley
I would suggest that you install a battery disconnect while you are doing it. I put a rotary one in the kick panel on the drivers side. It is behind the enrage handle and hidden very well.
Member # 28929
1995 Ford F-150
2015 Buick Enclave
Brad Ipsen CLC #737
Originally there is one clip to the frame about midway.  If it has the original cable in it you should see it.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
1940 Cadillac 60S Limo
tripwire
Thanks Guys.
I think I've decided to put the old girl up on jack stands and do it right instead of fast.
WParo in VT
Tom, thanks for the suggestion but someone put a master disconnect switch on the right front body mount down low at some point in the past.   I'm going to bypass it for now to see if that reduces the voltage drop I see in that circuit.
And, I'm not sure but I don't think my car has the enrage handle option.  At least I haven't found it yet.  My wife tells me I don't need one as I'm already on max enrage most of the time.
Driving now:
2023 XT4 Luxury
