Full Time Oil Filter for 59 390 Engine
Started by Bob S, September 02, 2005, 09:02:41 AM
Bob S
Hi,
I was wondering if the full time oil filter from a later engine can be installed on a 59 390 engine?  If so, how hard is it to do and what parts do I need?
Bob
Roger A. Zimmermann #21015
The engine block from 1959 does not has the provision to install the filter adapter. It wont be easy to do that conversion!
Roger
Bob S
Roger,
Thanks for the reply.  That is what I thought the reply would be.
John
Hello Bob,
I have a 390 in my 59 SDV and its oil filter is the spin-on type (AC # PF-24). It is located on the lower right side of the block (passenger side). This is the only one I have seen like this. Every one I have seen in person or in pictures has the canister mounted up on the front of the intake next to the radiator return. I dont know if this is an aftermarket item or not, but it has the AC logo casted on it. I admit it is much easier than the canister type, cleaner too!
I change the oil every two months and next time Im under there Ill look for a part# on the unit and forward it to you.
Good Luck,   John
Bruce Reynolds # 18992
Gday John,
Sorry to inform you but someone has changed the block in your car for a 60 to 62 part.
The spin-on filter didnt start till 60.
Bruce,
The Tassie Devil(le),
60 CDV
