Freeze Plug Diameter
Started by pauldridge, September 27, 2012, 08:34:33 PM
0 Members and 2 Guests are viewing this topic.
Tom Beaver
In the past the foundry used to in-bed wire in the sand molds to act as reinforcing bars.  After casting the block they would flush the sand out of the block cavity and usually removed the wire also, but not always.  I have seen this a time or two.  This is most likely what you see and you can just remove it and throw it away.
Tom Beaver
sjocad
I found it.
It was an old velding rod" there.May be lost when they took the dirt out.Now its ok.
Thanks folks... :-[
svein sjoblom,CLC # 12214.
1937 Lasalle opera coupe series 50.
