On The Road Help
Started by Gary Christensen CLC # 21112, September 15, 2017, 12:10:38 PM
Guys,
My '62 just started having trouble and I'm on a road trip.  At speed -- 50 or so -- it starts to miss and cut out.  My problem almost always is fuel pump so I keep a spare, but what is weird is that the car runs fine at slow speeds.  First gear, second gear, no problem.  Once into third, however, chug, chug, chug.
Any ideas?  Should I swap the pump?  Or could this be transmission?  Fluids are normal of course.
Gary
Dan LeBlanc
Still running points and condenser?  Could be that those are starting to fail at higher RPM and under load, although I wouldn't rule out the fuel pump either.  Check to make sure the pin that holds the pump arm in hasn't started to back out preventing full operation of the pump.  These pumps are notorious for that.
Also, pull the cap off the fuel pump . . . there's a little valve in there that tends to pop out (metal round disc).  If that's floating around in there, pop it back in and stake it to keep it from coming back out.  Just another area where these pumps (especially if rebuilt) can be weak.
Dan LeBlanc
Electronic ignition.
Got it.  I'll check.  I have a spare pump.
Thanks.
Gary.
Dan LeBlanc
Seems with the electronic ignitions, they work or they don't.  That's the good part.
Dan LeBlanc
New pump is on and all is good.
Does anyone know of a way to stop the ethanol from ruining the diaphragm?  Someone told me that there is some stuff that I can add to the fuel to prevent the ethanol from ruining things, but I'm not sure that I believe such a thing is possible.
Thanks for the help.
Gary
Lexi
Not sure if the '62 is similar to the one on my '56, but I once had a fuel issue that was similar. The pump was sucking in air through that big nut up on top. Because it was a suction leak I did not have gasoline leaking out, just air getting sucked in which revealed performance issues at higher speeds. Eventually I had starting issues as not enough gas was getting into the carb bowl. I installed a new metal/viton washer and wrapped the threads with gas fitter's tape. For a road trip, wrapping those threads would be a good fix for now, (just don't use teflon tape), Think the bolt size was 7/8 on my car. Hope this helps. Clay/Lexi
"Does anyone know of a way to stop the ethanol from ruining the diaphragm?"
Use a pump with an ethanol resistant diaphragm, any recent rebuilt pump should have the newer composition diaphragm.  Why it is not a good idea to use a NOS pump without replacing the diaphragm first.
David Greenburg
There are a variety of ethanol treatments out there.  A lot of people like Sta-bil.  Lucas makes one as well.
David Greenburg
'60 Eldorado Seville
'61 Fleetwood Sixty Special
V63
the alcohol is added as an oxident to accelerate gasoline decomposition. I'm not a chemist...but I think once mixed...the launch sequence has been initiated.
I have tryed stabil and others (that used to work on pure gasoline) and deemed them a waste of effort and money with alcohol blends.
