Author Topic: 1976 Eldo, turn signal switch removal.  (Read 938 times)
dave hanson
  • Guest
« on: August 14, 2009, 04:41:29 PM »
there is a rectanqular plate where the screw that holds the switch arm on would normaly be. appears to be no way to remove the arm
Offline Ted in Olympia WA
  • 25659
Re: 1976 Eldo, turn signal switch removal.
« Reply #1 on: August 14, 2009, 05:24:38 PM »
The arm unscrews.  At the base you will see a flat spot for a wrench or pliers.  What you have to watch out for is breaking your cruse control wire when you unwind it.
TED
Offline The Tassie Devil(le)
  • Administrator
      CLC Member #18992
  • Name: Bruce Reynolds
« Reply #2 on: August 15, 2009, 05:35:53 AM »
The Workshop Manual is very specific in describing the removal and replacement of the arm.
It mentions that the arm takes 6 turns to remove, and when replacing, the wire has to be wound on 6 turns before attempting to re-install.
dave hanson
  • Guest
« Reply #3 on: August 15, 2009, 12:54:45 PM »
Thanks, Ted and Bruce , for the info
