Author Topic: 59-60 heater hoses  (Read 1089 times)
Offline David Greenburg
  • CLC #3830
      CLC Member #3830
  • Name: David Greenburg
59-60 heater hoses
« on: February 25, 2013, 12:03:57 AM »
I bypassed my leaky heater core and now that I'm getting ready to fix  it I've lost track of which hose goes to which side of the water pump. Can any of you 59-60 guys help me out?
David Greenburg
'60 Eldorado Seville
'61 Fleetwood Sixty Special
Offline Jeff Wilk
  • J. Wilk CLC # 25630
  • The Past + The Future = My Heaven on Earth
      CLC Member #25630
  • Name: Jeff Wilk
Re: 59-60 heater hoses
« Reply #1 on: February 25, 2013, 07:18:39 AM »
Dave they should be two different ID's to match the pipe sizes at the core and at the pump.
Central New Jersey
SOLD
1958 Cadillac Sixty-Special
1958 Cadillac Sedan
1958 Cadillac Coupe Deville
  • CLC #3830
      CLC Member #3830
« Reply #2 on: February 25, 2013, 12:31:58 PM »
Thanks, Jeff. I think the hoses on the car are the same size,  but that may be due to previous incompetent work.  If the fittings are different sizes, that should solve the problem, and perhaps a leak.,
David Greenburg
Offline Ed Mobley
« Reply #3 on: February 26, 2013, 03:04:43 PM »
Hi,
The larger hose is on the passenger side of the water pump and the smaller hose is on the driver side of the water pump.
Ed
Offline Dan LeBlanc
  • Administrator
      CLC Member #27657
  • Name: Dan LeBlanc
« Reply #4 on: February 26, 2013, 04:20:27 PM »
If they're like 61/62, one should be 5/8" ID and the other 3/4" ID
Dan LeBlanc - CLC # 27657
1970 DeVille Convertible
1977 Continental Town Car
  • CLC #3830
      CLC Member #3830
« Reply #5 on: February 27, 2013, 12:38:57 AM »
Thanks, all.  Putting on the correct (different sized) hoses makes it pretty clear what goes where.
David Greenburg
Offline 60eldo
  • EVERYDAY ABOVE GROUND IS A GOOD DAY
  • Name: Johnny.K. CLC MEMBER #27762
« Reply #6 on: February 27, 2013, 11:05:55 AM »
   Check the 1959 manual, it show pics of the hoses and where they go page 14-28
J. Kluczynski
Offline 76eldo
      CLC Member #22443
  • Name: Brian Rachlin
« Reply #7 on: February 27, 2013, 11:14:00 AM »
If you need photos let me know.  One of the hoses goes under the manifold from front to back.
CLC # 22443
I prefer email's not PM's   rachlin@comcast.net
1960 62 Series Convertible with factory Tri Power
1960 Eldorado Seville
1970 Eldorado
1976 Eldorado Convertible
1980 Eldorado Hess & Eisenhardt Convertible
1981 Eldorado Hess & Eisenhardt Convertible
1985 Eldorado ASC Biarritz Convertible
2007 DTS
2017 CT5
  • CLC #3830
      CLC Member #3830
« Reply #8 on: February 28, 2013, 01:33:19 AM »
I looked in the manual but missed that picture.  On my car, as well as my '59, both hoses run under the manifold.  My back has been acting up and I decided I didn't want to fight the battle of pulling the dash in order to get to the heater core, so I took it to my professional guru, an old school mechanic, who was able to remove the heater core without pulling the dash.  Despite the shop manual, apparently you can get to the core after removing the glove box and glove box door.
David Greenburg
