Author Topic: 1940 LaSalle Tightening torque  (Read 796 times)
Offline Hans Ackermann
  • Name: Hans Ackermann
« on: March 10, 2014, 02:37:04 PM »
I'm stuck on my project and I was wondering if someone knew what the tightening torque is for the nut that keeps the bearing in place at the rear axel.
Thanks in advance. Hans Ackermann
1940 LaSalle Ser.50 Model 5011 2-door
1918 Ford Model T Touring
1950 Rex Villiers Road Master
Offline Warren Rauch #4286
Re: 1940 LaSalle Tightening torque
« Reply #1 on: March 11, 2014, 07:09:24 PM »
  You probably are not going to find the spec. Cadillac for many years did not permit its Service Stations to service rear axles. They required them to remove the carrier (nose) and return it to factory for service. Are you looking for nut on the pinion shaft or the side carrier bearing?
   There is a spec for the pinion nut for 1941-52 except series 75 and CC.  These used a 7/8 " shaft (225ft/lb). I believe your shaft is 1/2" , the same as the 75/CC above. Don't try anything near 225! In the shop manuals they give instructions on replacing the pinion seal,of this period. They tell you to measure the torque it takes to turn the carrier BEFORE you remove the nut , and then tighten it to return that  torque (drag).Warren
« Reply #2 on: March 12, 2014, 11:54:04 AM »
It ist the nut 1-5/8'' out side off the brake drum.
Sorry for my bad explanation...
Online Steve Passmore
  • Name: Steve Passmore
« Reply #3 on: March 12, 2014, 11:58:27 AM »
I don't think there is a setting for the drum nuts, I stand on a 2 foot bar till it won't move anymore.
Offline harry s
  • Harry Scott 4195
      CLC Member #4195
« Reply #4 on: March 12, 2014, 06:57:19 PM »
The 1948 shop 'manual gives a torque tightness of 285 to 315 ft lbs on a 1" 14 thread size. That should be about the equivalent of standing on the two foot pipe.     Harry
Harry Scott 4195
1937 7529
1941 6733
1948 6267X
« Reply #5 on: March 13, 2014, 02:35:53 PM »
Tank's for all the good help !!  I am very grateful.
/ Hans Ackermann ( Sweden.)
