Author Topic: 1929 LaSalle Town Sedan - Restoration Questions  (Read 735 times)
Hank Vander Werp
  • Guest
« on: June 12, 2009, 09:30:52 PM »
We are beginning the restoration process on a 29 LAS Town Sedan.  Would appreciate your input on any of the following:
       1.  Who would you recommend to contact for a complete exhaust system?
       2.  Where would I find a replacement for a worn out fan hub shaft?
       3.  We are looking for a number of parts:  hotbox, carb heater control and exhaust connection, box or cover located in the
            lower rt hand side (driver side) of the engine compartment that cover a number of seemingly lose wires, new instrument
            panel housing, clock for the instrument panel, the small chrome bracket that hold down the rear of the hood.
Those are some of the items we have identified thus far with a month into the project.  Any help would be greatly appreciated.
Hank
Offline Brorag
  • Name: John Dellinger
Re: 1929 LaSalle Town Sedan - Restoration Questions
« Reply #1 on: April 22, 2013, 04:44:28 PM »
I'm doing a '29 LaSalle also.
Did you rebuild the water pump? If so, how did you break apart the water pump housing to replace the seals?
John Dellinger
