Author Topic: Wanted 472 / 500 rear sump oil pan and pick up tube  (Read 1276 times)
Offline brian faull clc#25881
      CLC Member #25881
« on: January 28, 2011, 05:47:32 PM »
If you have a rear sump oil pan and pickup for sale let me know. Thanks, Brian. 412 952 6027.
Offline TJ Hopland
Re: Wanted 472 / 500 rear sump oil pan and pick up tube
« Reply #1 on: January 28, 2011, 07:46:36 PM »
In stock Cadillac land this is known as a 68-78 Eldorado pan.     The 68-69 472 had a smaller pickup tube than the 70-76 '5200' block 472 / 500 and 77-78 425.
For those that are curious the 68-76 rwd cars used a pan that had the sump in the front.  77 with the downsizing they moved it back to a more normal GM rear position.  The reason most people without Eldos want the 'eldo' pan is to fit a caddy motor in a car that may or may not have even had room for a small block chevy motor.  Most of the larger swaps (like trucks) work with the 77-81 pan.
StPaul/Mpls, MN USA
73 Eldo convert w/FiTech EFI
75 Eldo rusty but trusty
80 Eldo Diesel
The 2017 CLCMRC Calendar is available!
15 Beautiful Cadillacs and LaSalles.
Only $15 +S&H.
ORDER HERE!
