Mike,
I may or may nor have the lines going into the firewall correct, as I disconnected the vacuum line because there was a hissing from the radio. (Power antenna)
Upon pressing the washer button, one of two lines sucked, so I connected that to the washer bottle ( there are 2 lines on the washer bottle). I NOW heard a WET sucking sound but no water coming from the sprayers.
So is it correct? I am not sure. I disconnected the line until I can repair it, and that will be some time as I recover from surgury.
I also had the heater fan rebuilt just so it works, not to really be used. I also fixed the back cigarette lighter and I no longer smoke, nor sit in the back seat OR would I allow anyone to smoke in the car for fear of burning the original upholtery.
I suppose I want as much perfect and operational in the car just to say it works.
So, it is the same thing with the lines. Even though I would never use the washers, I would like them to work.
Thank you for your reply. It seems so hard for anyone to get vacuum line, heater line or simple electrical routing here in the forum. I find little use of the manuels available, if they mention these at all.
Good luck,
Richard
