All on the same circuit, power on both sides of the fuse?, body feed/courtesy lite/cigar liter? Pinion needs to be replaced of course, not a big deal, fill the diff and drive it unless the leak is pouring out, usually that is not the case, if you fill and it is a slow drip it still can be driven.
