Author Topic: How in the heck do you get this thing off?!?!?!?!  (Read 588 times)
Offline mike12485
  • Name: Mike Spera
« on: April 29, 2012, 12:13:04 PM »
OK, I have to ask. How in the heck do you get that stupid slip joint loose on the exhaust collection box on the top of the 1932 V8 engine?  We have heated it, banged on it, and hit it with enough Kroil to float a battle ship. I'm out of ideas can some one help me?
Best,
Mike Spera
Offline harry s
  • Harry Scott 4195
      CLC Member #4195
Re: How in the heck do you get this thing off?!?!?!?!
« Reply #1 on: April 29, 2012, 06:26:29 PM »
Hi Mike,   Are you talking about the exhaust pipe or manifold connections or the exhaust pass throgh at the intake manifold?  Do you have a picture>    Harrry
Harry Scott 4195
1937 7529
1941 6733
1948 6267X
Offline Paul Ayres #5640
      CLC Member #5640
« Reply #2 on: May 10, 2012, 10:10:54 PM »
Mike - As you have found out, this joint rusts tight.  I had to cut the pipe close to the hub welded onto it and slit the portion of the pipe that extends into the hot box in order to collapse it a bit to get it loose.  I was going to make up a new pipe and covering anyway, so destroying the pipe had no consequences for me.  If you need to save the pipe, I can only suggest more heat and more penetrating oil.  Paul Ayres #5640
Cadillac & LaSalle Club Visa
