1949 Cadillac Ignition Switch Question
Started by Bill Bickle 15098, August 07, 2012, 04:14:04 PM
Bill Bickle 15098
On the rear of the ignition switch there are three terminals. Top, middle and bottom. in a triangular pattern with the middle terminal on the driver's side of the switch when the switch is installed its proper position (keyhole in vertical postion).
I wish to verify the connections since I have not found a clear schematic of this switch.
With the switch in its proper position, I have connected the coil wire to the bottom terminal, the battery wire to the middle terminal (driver's side terminal) and all accessories to the top terminal including the starter button lead.
My accessories are: radio, heater-defroster and cigarette lighter.  These are all connected to the top switch as well the starter button lead ( 4 wires). It seems a little excessive for one terminal!
Do I have the leads on the correct terminals?
1927 (7400) and 1940 (5267) LaSalles; 1949 Cadillac 6107
Jeff Maltby 4194
You have it right Bill.
Jeffo 49er chapter
CLC 1985
Honda Gold Wing GL1500
Jay Friedman
Jeffo,
Can you scan your drawing of all the electrical connections a bit better so the margins are visible and send me a copy for the newsletter of the Forty Niners Chapter.
jay
1949 Cadillac 6107 Club Coupe
Decatur, Georgia
CLC # 3210, since 1984
R Sotardi #11719
Is the 1950 ignition switch the same as the 48 &49s? Bill, I went to my 1950 wire diagram Looking from the rear of the dash, I can see the reason for your concern. I guess that the letters  A B & C(coil) are the best indicators. Ron
Jeff Maltby 4194
Here's my oem harness attached to the switch.
Jeffo 49er chapter
CLC 1985
Jeff Maltby 4194
#5
Jay. Remember when I told you my dash is partially undercoated, the only one I've ever seen since , having parted out many 49's since 1985.
Jeffo 49er chapter
CLC 1985
