Author Topic: Freeze Plug Diameter  (Read 4145 times)
Offline pauldridge
  • Phil Auldridge
  • Name: Phil Auldridge
« on: September 27, 2012, 07:34:33 PM »
Last Sunday evening I was barrelling along the interstate in my '59 Jaguar when I heard a loud metallic clang.  As it turns out, I've had a slight weep around one of my block core (freeze or Welsh) plugs.  Soon as I heard the noise, my first thought was that plug might have blown.  Pulled off at the exit and shut her down quickly.  Yep, sure enough, that plug was completely gone from the block (as well as all my coolant).
While asking on the Jag forum for any hints on replacement, someone suggested using the Dorman copper plugs, which have a tightening bolt to insure it won't come out.  My order came today, and the installation took all of 15 minutes, including cleaning up the recess in the block.  These things look great! (pic below).  They can be had for about $4 each (or as much as $29 if you buy from the wrong place).
Now I want to use these in the 346 flathead I'm currently rebuilding.  Unfortunately, my block is at the machine shop.  Wonder if anyone knows the diameter and quantity of plugs used in the Caddy?
Phil Auldridge
Austin, TX
Offline John Washburn CLC 1067
  • Call me on my shoe phone 303+885-3545
      CLC Member #1067
Re: Freeze Plug Diameter
« Reply #1 on: September 27, 2012, 08:58:11 PM »
Paul,
I do and have one in it original package. But you have to share where to get thses first, the low priced ones. Then I will post a picture of the same unit and size.
John Washburn
John Washburn
CLC #1067
1937 LaSalle Coupe
1949 62 Series 4 Door
1953 Coupe DeVille
1956 Coupe DeVille
Offline pauldridge
  • Phil Auldridge
Re: Dorman Freeze Plug Sources
« Reply #2 on: September 29, 2012, 07:00:11 PM »
Quote
John Washburn
Sure, heh heh... no secret:
First I went to the Dorman site to find the part number of the specific diameter I needed http://www.dormanproducts.com/gsearch.aspx?type=keyword&q=expansion+plugs
Then found a source at www.partsgeek.com  These particular ones I purchased were 1 7/8" diameter (with, ironically, metric sizes on the tightening nuts) and come in lots of 5 @ $3.60 each.  It was well under $30 for 5 and shipping.
Partsgeek uses the same parts numbers as Dorman, but it can be a  to find these on their site since they want a car year and model before giving you the part.. I think I just stumbled onto Partsgeek doing a google search for my desired Dorman part.
Now I see looking at www.summitracing.com their pricing isn't so bad, it is also for qty 5, not one, @ $24.95, and easier to find.  Just search for Dorman ###-### and it will pop up.
Phil Auldridge
Austin, TX
      CLC Member #1067
« Reply #3 on: September 29, 2012, 09:28:42 PM »
Phil,
Tried to attach picture of the Droman Core plug but the web page won't let me... Pictures are small enough to post so not sure what is going on.
Have not been able to find these plugs, perhaps you will have better luck...
Dorman 1 3/4"
Part # DC 11 SP
They probably still make but under a different parts number!!
Was going to send to your e-mail but could not find you in the directory. So if you want the pictures send you e-mail.
John Washburn
John Washburn
CLC #1067
1937 LaSalle Coupe
1953 Coupe DeVille
1956 Coupe DeVille
      CLC Member #1067
« Reply #4 on: September 30, 2012, 05:16:29 PM »
Trying to send picture again.
jw
John Washburn
CLC #1067
1937 LaSalle Coupe
1953 Coupe DeVille
1956 Coupe DeVille
Offline pauldridge
  • Phil Auldridge
Re: Freeze Plug Source
« Reply #5 on: October 02, 2012, 10:22:46 AM »
John thanks for the pic, and the dimension
Here's the link oin the Dorman site for the 1 3/4" plug http://www.dormanproducts.com/p-28443-568-011.aspx
It is Dorman part number 568-011.  One source is Amazon.. although not specified in this listing, they seem to come in packs of 5 so I assume the price is for qty 5
http://www.amazon.com/Dorman-568011-Expansion-Plug-568-011/dp/B005GMAAQQ/ref=sr_1_3?ie=UTF8&qid=1349191210&sr=8-3&keywords=dorman+568-011
Phil Auldridge
Austin, TX
Offline Bob Hoffmann CLC#96
      CLC Member #96
« Reply #6 on: October 02, 2012, 11:50:16 AM »
Phil,
 Are those brass or steel? Are you willing to accept steel? Advise, Bob
1941 62 coupe custom maroon
1970 DeVille conv. triple black
      CLC Member #1067
« Reply #7 on: October 02, 2012, 12:18:41 PM »
Phil,
Looks like you are correct packs of 5.
Rockauto.com has them for $2.98 each, but you have to buy 5.
O'Reilly Auto Parts has them for $3.98 each but again you have to buy 5.
For me Tax vs shipping makes the cost a wash.
Thanks for the help
John Washburn
Bob, They are copper...
John Washburn
CLC #1067
1937 LaSalle Coupe
1953 Coupe DeVille
1956 Coupe DeVille
Offline dirkdaddy
  • Name: S. Philbrookski
« Reply #8 on: November 28, 2012, 12:03:00 PM »
I installed the "correct" freeze plugs in my flathead LaSalle and had one blow out @ 5psi under pressure testing the system.  ???  They are convex without a rim, and with the flange on the inside of the block pretty much requires one to install them with the convex side out - plus the mfg. lettering is on that side. I used Permatex the gasket coating old school stuff as was advised, but it blew out after some testing. My dad whos nearly 80 was subsequently telling me I should have hit the center of them with a punch to "spread them" and keep them from popping out.
Any input guys?
Scott Philbrook
Houston tx
      CLC Member #1067
« Reply #9 on: November 28, 2012, 12:52:12 PM »
Dirk,
Yep got smack them to seal the core plug otherwise as you have figured out the fall out.
Trust your dad.
That is why I use the copper ones that have a nut to tighen them up from Dorman.
Good Luck
John Washburn
CLC #1067
1937 LaSalle Coupe
1953 Coupe DeVille
1956 Coupe DeVille
Offline sjocad
  • Cadman from Norway
  • Name: Svein Sjoblom
« Reply #10 on: January 28, 2013, 01:42:07 AM »
Hi Folks.
As far as I can see,the Brass plugs to 472 & 500 Cadillac fits.
Trying to put in a photo,but,???
svein sjoblom,CLC # 12214.
1937 Lasalle series 50 Opera Coupe
1959 cadillac coupe deville series 63.
1996 Fleetwood Brougham Gold Edition
Offline kkarrer
  • Name: Ken Karrer
« Reply #11 on: January 28, 2013, 03:18:35 PM »
Right, smack 'em in the center (convex side out), but I'd also recommend putting some of the "slow" JB weld around them and be certain that the inner surface is clean.  One of mine blew out and really overheated the engine and cost me a tow.  I have some of the original style Dormans if someone needs them.
Ken Karrer 1941 6227D coupe
Offline sjocad
« Reply #12 on: January 28, 2013, 08:27:39 PM »
Hi.
 JB weld,???? Tell me what that is.
Thanks,,,sjocad ;D
Offline kkarrer
  • Name: Ken Karrer
« Reply #13 on: January 29, 2013, 08:28:05 AM »
JB Weld is an epoxy that is sold at places like Home Depot and Lowes in their paint and adhesives aisle.  It comes in two types.  One is quicker setting.  You want to use the slower setting stuff.  Once it sets up it can be drilled and tapped and holds up to high heat and chemicals like gasoline and oil.  After cleaning the surfaces, mix a little JB and smear it on both surfaces and then put the plug in place and strike the center with a punch and hammer.  I then take a rag and dip it in solvent and wipe off the excess.  I don't try to get it too clean because after 24 hours I paint it with the Cadillac green engine paint.
Offline Classic
  • CLC # 474
      CLC Member #474
« Reply #14 on: January 29, 2013, 12:34:51 PM »
I see you are from Norway (Norge).  You can buy JB Weld from Westfalia in the UK (a mail order house): http://www2.westfalia.net/shops/tools/adhesives_and_glues/adhesives/2_component_glue/702795-jb_weld_adhesive.htm.
or you can Google JB Weld on Google.no.  I think it's probably available in your country too.
Gene Menne
CLC #474
Offline pauldridge
  • Phil Auldridge
« Reply #15 on: January 30, 2013, 05:08:43 AM »
Dorman Copper plugs...
One caveat... because of the extra thickness of these plugs (with the bolt in the center) I found the starter could not install, so had to remove it and use a regular convex plug.  Seems like there was one on the other side where I ran into the same problem.  Check clearance with accessories before using the Dorman
Phil Auldridge
Austin, TX
Offline sjocad
« Reply #16 on: February 02, 2013, 07:30:02 AM »
Thanks FOLKS.. :D
Offline sjocad
« Reply #17 on: February 04, 2013, 11:24:03 AM »
Hi all of you.
WOW,today I found something Crazy.
First;I found the orginal Freeze plugs on Ebay today.Oval.I pulled all 3 on left side out,and HO..A LOT of dirt..
Number on them was 1-47/64. Then I found one in my garage with number  P 103,,, 1|-47/64.So that fit.Its oval too.
Now lissen.On left side,inside first hole from front,it was a "vire"or looked like an OLD welding rod inside there.
It was from the front,and back to the plug number TWO...?????????????????(middle) Its 3 one the side you know.
What in the heck is THAT,??? Heatsensor from Dach,????
I have never seen anything like it.Its loose too,but I was afraid to take it out.
Do You Steve Passmore know,?? You have for sure overholed your Lasalle 38.
Anybody who can tell me,??? I havent taken the heads of yet...This os crazy,hoho :-[ ;D ::)
Regards Crazy old cadman from Norway
Offline sjocad
« Reply #18 on: February 06, 2013, 06:57:07 AM »
Nobody could help me,????
Regards,,,svein
Online The Tassie Devil(le)
  • Administrator
      CLC Member #18992
  • Name: Bruce Reynolds
« Reply #19 on: February 06, 2013, 05:21:21 PM »
The one with the "wire" attached could well be a worn out "Heating Element" for pre-heating the engine coolant in the COLD Winter areas of USA to keep the block from cracking when the coolant freezes.
'55 Buick Special Post Coupe (LHD)
'74 Chris Craft Gull Wing RHH
