Changing a 47 Flathead to a 12 volt
Started by Cadillac Slim, October 30, 2012, 08:33:59 PM
Cadillac Slim
I want to change my 47 flathead to a 12 volt.  I do want to keep the original generator look.  Does anyone know of an alternator out there that looks like the old Delco generators?
1938 Lasalle - Sold
1940 Lasalle Conv. - Sold
1947 Series 61 Sedanette
1953 Coupe De Ville
1957 Coupe De Ville
1959 Series 62 2 Door
1960 Coupe De Ville
1964 Eldorado
1964 Coupe De Ville - Sold
1966 Coupe De Ville
1968 Conv. - Sold
1984 Eldorado Biarritz Conv. - Sold
2003 Deville - Sold
2004 Seville
Doug Houston
38-6019S
38-9039
39-9057B
41-6227D
41-6019SF
41-6229D
41-6267D
56-6267
70-DeV Conv
41-Chev 41-1167
41 Olds 41-3929
wrench
I have been thinking about this. I am still running 6v and probably won't convert to 12v, apparently, this guy does 6v gener-nators upon request...
http://www.gener-nator.com/
1951 Series 62 Sedan
1969 Eldorado
1958 Apache 3/4 ton 4x4
2005 F250
2014 FLHP
2014 SRX
Cadillac Slim
Called gene-nator & they will rebuild your generator to a 12v system for $895.00 with core charge. 60 amps.
I found these as well for $421.00.
http://www.powermastermotorsports.com/powergen.html
1938 Lasalle - Sold
1953 Coupe De Ville
1957 Coupe De Ville
1960 Coupe De Ville
1964 Eldorado
1966 Coupe De Ville
1968 Conv. - Sold
2003 Deville - Sold
2004 Seville
wrench
Quote from: Cadillac Slim on October 31, 2012, 04:59:31 PM
Wow. $895, Jeez, that's not even close to practical.
Thanks for the info on the power gen...
1969 Eldorado
2005 F250
2014 FLHP
2014 SRX
LeRoy DeVol
Darin, My 1947 Cadillac was converted to 12 volts & the generator conversion was not hard to do. You will need to get a 12 volt gen. from a cad. of the 60's with A/C along with the proper voltage regulator. You will need to install the front mounting plate with bearing & the rear plate with bearing from your 47 generator using the armature & field from the 12 volt generator. The next thing is to install the pulley from your 6 volt gen. After this you install the regulator & you are good to go. The gen. for a car with A/C is heavy duty & is a better choice. Make sure you use the proper regulator for the gen. or you will be in trouble. This conversion will be cheap & easy to do. If you decide to do this E mail me & i will give you all the other information you will need to do this. The total cost will be about $600.00. You might want to go to a professional starter & gen. shop to convert your gen.
Lee DeVol
Whit Otis, 1188
Why do you want to go to all this trouble?  What's wrong with your 6 volt system?
Whit
Whit Otis -
1941 6219D Custom
1941 6219D
1940 7533F
1986 Mercedes Benz 560 SEL
1999 Bentley Arnage
2019 XT5
Drawing of AP Sloan Custom by Terry Wenger
LeRoy DeVol
Whit, There is nothing wrong with a 6 volt system on a old Cadillac as long as the cables are heavy & the battery is high cranking amps. The reason most people convert to 12 volts is they can add A/C, stereo, electric fan, & charge there cell phones on a road trip. Also you can find 12 volt parts when you need them. Other then that a 6 volt system works great.
Lee DeVol
kkarrer
The power-gen costs about $350.  I put one in my 50 coupe a few years back when I did a 12v conversion (including getting rid of the points and condenser).  I sold that car to a guy in Holland and he still sends me a postcard every Christmas.
Ken Karrer 1941 6227D coupe
