Author Topic: 1965 Cadillac wing window weather stripping  (Read 375 times)
Offline Scot Minesinger
      CLC Member #20543
« on: February 25, 2013, 10:07:54 PM »
Installing the weather stripping on a 1965 Cadillac wing windows and after removal of the original material there is no adhesive residue.  Do I install the weather stripping with no adhesive or with adhesive?
Offline Ralph Messina CLC 4937
      CLC Member #4937
Re: 1965 Cadillac wing window weather stripping
« Reply #1 on: February 25, 2013, 10:46:36 PM »
Scott,
The originals had two barbs crimped on the rubber that held the rubber in the channel. The replacements do not, and I had to improvise buy shaving off the small longitudinal rubber ribs that fit in the groove. After successive approximation to get a satisfactory dry fit, I put a little adhesive in the bottom of the groove for security. I then taped the vent window closed so the rubber would take a set.
Ralph
1966 Eldorado  http://bit.ly/1OrxLoY
2010 GMC Yukon
      CLC Member #20543
« Reply #2 on: February 26, 2013, 07:05:25 AM »
Ralph,
