The changes to make the forums only allow posting by CLC members have been completed. If you are a CLC member and are unable to post, please send the webmaster your CLC number, forum username and the email in your forum profile for reinstatement to full posting and messaging privileges.
55 Oil Bath Air Cleaner Housing Movement
Started by D.Yaros, January 17, 2014, 03:51:32 PM
D.Yaros
Wondering what techniques you have used to stop the oil bath air cleaner housing from rotating/moving on the carburetor air horn?
Dave Yaros
CLC #25195
55 Coupe de Ville
92 Allante
62 Olds
Jon S
Do you have the air horn gasket under the air cleaner?
Jon
1958 Cadillac Sedan De Ville
1981 Corvette
2004 Mustang GT
D.Yaros
Dave Yaros
CLC #25195
55 Coupe de Ville
92 Allante
62 Olds
Dave,
This is an interesting question. On my 1953 CDV, when I changed to the paper air filter, it kept moving. On my 56 CDV, with the same modification, no problem.
I changed air filter parts on the 1953, changed the carburetor from a Carter to a Rochester and it still rotates.
Finally, put some a nut and washers under the top of the air cleaner cover and then tighten it down and it seems to be behaving. Not sure what is going on, but the top is flexible if there is no original oil bath/muffler underneath it.
The Johnny
John Washburn
CLC #1067
1937 LaSalle Coupe
1949 62 Series 4 Door
1949 60 Special Fleetwood
1953 Coupe DeVille
1956 Coupe DeVille
joeceretti
Why not put a length of steel or copper tubing inside the air cleaner around the tie down rod to support the cover from compressing and working loose?
