Author Topic: Caddy parts mostly 50-60, some 70s  (Read 1669 times)
Offline arch62
      CLC Member #30767
  • Name: P. Paraskis
Re: Caddy parts mostly 50-60, some 70s
« Reply #20 on: September 23, 2017, 10:15:47 AM »
Thanks Chuck for hunting. The '62 - '63 cruise control started using a wheel. Other years are not usable.
Good luck at the show.
Offline Dan LeBlanc
  • Administrator
      CLC Member #27657
  • Name: Dan LeBlanc
« Reply #21 on: September 23, 2017, 12:37:21 PM »
You are essentially looking for a one year only part that was prone to breakage. Almost always the gear in this setup is broken. I believe fellow CLC member Steven Tuck had the gear remade in some sort of metal for his car some time ago.
Dan LeBlanc - CLC # 27657
1970 DeVille Convertible
1977 Continental Town Car
      CLC Member #8621
  • Name: Eric DeVirgilis
« Reply #22 on: September 23, 2017, 01:34:56 PM »
For the E Brake of a 1959 Cadillac - do you have the silver J rod with threaded end in the center of the picture? May fit other years. Probably the same as 1960.
Also need passenger side Vent Control cable (no air conditioning car).
No "J" hook, but can't you buy a stainless J hook form Home depot, that looks the same.   Part of guy wire hold down kit.  Chuck
« Last Edit: September 24, 2017, 03:48:46 PM by Chuck Swanson »
A Cadillac Motorcar is a Possession for Which There is no Acceptable Substitute
Online Ralph Messina CLC 4937
      CLC Member #4937
« Reply #23 on: September 24, 2017, 11:04:45 AM »
Hi Chuck,
I sent you a PM. Please check you mail.
Ralph
1966 Eldorado  http://bit.ly/1OrxLoY
2010 GMC Yukon
Offline Chuck Swanson
  • Administrator
      CLC Member #26619
  • Name: C. Swanson
« Reply #24 on: September 24, 2017, 03:57:11 PM »
Only rear in teal and jade.  I have some more of these in a closed case-rear though.
66 DeVille Convertible (3)
64 Series 62 (2)
64 2 door
66 Sedan DeVille hardtop
65 Eldorado Bk/Bk
69 DeVille vert
97 DeVille d'Elegance
67 Chevy II Nova (AACA GN 2016)
69 Dodge Coronet R/T
98 American Tradition 40' DP RV
AACA Lifetime
      CLC Member #8621
« Reply #25 on: September 25, 2017, 08:36:52 AM »
Thanks Chuck. I thought of that but was concerned about the tensile strength. May go that route if no other option.
Offline monibrian
  • Name: brian c roberts
« Reply #26 on: September 25, 2017, 08:49:54 AM »
Chuck....anything for a '68 deville.  Looking for trunk V emblem...upper bumper bar...trunk cadillac emblem cover...red seat belts for front....thanks for checking.
  • Administrator
      CLC Member #26619
  • Name: C. Swanson
« Reply #27 on: September 25, 2017, 08:51:21 AM »
Possibly the non-stainless version is stronger, but maybe a quick check with manufacturer as they are used for holding guy wires, so they may have some spec (ie close to grade 8 or not??)
64 Series 62 (2)
64 2 door
65 Eldorado Bk/Bk
69 DeVille vert
AACA Lifetime
Offline smatarese
  • CLC Member #29516
      CLC Member #29516
  • Name: Stephen Matarese
« Reply #28 on: September 25, 2017, 04:46:32 PM »
Do you have the vertical bar and 3 bullets to the left of the gas filler door for a 59 Eldorado rear grill? I can post a photo tomorrow for clarity.
Offline lexi
      CLC Member #28634
  • Name: C.R. Foley
« Reply #29 on: September 28, 2017, 01:49:41 PM »
Will PM you regarding a generator. Clay/Lexi
  • Administrator
      CLC Member #26619
  • Name: C. Swanson
« Reply #30 on: September 28, 2017, 03:08:18 PM »
1960 grills and parts, but no '59.
I have 5 generator, and will check. Thanks!
64 Series 62 (2)
64 2 door
65 Eldorado Bk/Bk
69 DeVille vert
AACA Lifetime
Offline gmader
  • Name: George Mader
« Reply #31 on: September 28, 2017, 07:54:36 PM »
Chuck, do you happen to have any window frames for 1960 Series 62 convertible?  Really need the rear quarter window behind the driver.  Bought the car 15 years ago with a crack in the pivot corner of the frame (very common) and would finally like to get it fixed.  Hopefully with something that will last.
Offline lexi
      CLC Member #28634
  • Name: C.R. Foley
« Reply #32 on: September 29, 2017, 09:46:32 AM »
Chuck thanks! Clay/Lexi
Offline BeavertonMike
  • Name: Mike Cole
« Reply #33 on: October 09, 2017, 08:03:20 PM »
Hi Chuck, do you have any body parts for a 62 Sedan de Ville? Or know of a parts car with a good body?
