Please note that the Forums will be in Maintenance Mode, i.e. not accessible, this coming Wednesday, May 15th, This is to make backups and carry out the changes to make the forums only allow posting by CLC members. The start of the transition is planned for around 9 a.m. EDT, and is expected to last between four and eight hours.
1962 Master Cyl and booster
Started by Skwerly62, August 10, 2019, 06:04:01 PM
Skwerly62
Looking for a good used or rebuilt Master and booster to convert a 59 to dual reservoir. Located in PA thank you!
1958 Extended Deck 62 Sedan SOLD
1960 Coupe - current project
USCG Vet - Fly CG!
marty55cdv
    I just used this set up on my 1960 for drum brakes so basically no proportioning valve you can run lines out either side. Fits in the firewall and bolts right up.   https://www.performanceonline.com/1959-62-Cadillac-Power-Brake-Booster-Conversion-Kit-/
Marty Smith
  CLC #22760
41 60 Special http://bit.ly/1Wm0GvT
55 CDV http://bit.ly/1G933IY
56 Fleetwood
1958 Extended Deck http://bit.ly/1NPYhGC
1959 Fleetwood  http://bit.ly/1OFsrOE
1960 Series 62 Coupe
1960 Sedan DeVille  4 window Flattop
63 Fleetwood http://bit.ly/1iSz17J
1964 Eldorado http://bit.ly/1Wm17GA  (Living in California now)
1988 EBC http://bit.ly/1iSACKz
Skwerly62
Thanks Marty helping out a non-CLC 59 owner get his on the road.
USCG Vet - Fly CG!
