The changes to make the forums only allow posting by CLC members have been completed. If you are a CLC member and are unable to post, please send the webmaster your CLC number, forum username and the email in your forum profile for reinstatement to full posting and messaging privileges.
‘75 Eldorado Sun Visors Just Won’t stay Up
Started by KWirth, August 02, 2021, 04:20:27 PM
KWirth
Both my sun visors on my '75 Eldorado won't stay up.  Then drop down at the slightest bump in the road and it's annoying.  I have the set screws on both as tight as I can get them and they still drop down.  They are original and in great shape so I'm hoping someone out there has a fix for this issue.  Thanks!
Cadillac Fleetwood
This is caused not because the visor is loose on bracket, but because the cylindrical rod is loose and is rotating within the metal support on the windshield header.  The solution may be to drill a hole through the bracket and cylindrical rod and insert some sort of drift pin to prevent rotation of the rod.
-Charles Fares
1970 Fleetwood Brougham
1969 DeVille Convertible
1989 Fleetwood
KWirth
Thanks for the quick reply Charles.  I'll check that out and give your suggestion a try.
Best regards,
Ken
MaR
I have found that it is usually the plastic liner over the rod that goes into visor is worn and not letting the screw tighten up.
Easy to check. Just loosen the screw and slide the visor off. If the "pin" is loose (most likely) you can rotate it. I typically drill a hole the same size as a very small finishing nail, insert the nail and clip the overhang off leaving about 1/16" which I bend slightly to hold the nail in place.
KWirth
Thanks for the suggestions.  I just checked it out and both pins were indeed loose so I implemented your suggestion and it worked great.  I broke one drill bit in the process but it's worth it for not having the visor drop down all the time while I'm driving.  I used a small thin finishing nail that has a flat head on top.  I dipped each nail down the tube of weather strip adhesive, put it through the hole from the top and neatly cut off the end with a small hacksaw blade.  Filed each pin on the bottom and cleaned off the excess weather strip adhesive. No one will ever know there was a repair.
You guys, and this club, are the best!  I've gotten great advice and also found great NOS parts for my restoration.  Thanks again
amarzano
Isn't there a plastic grommet that goes into the visor that corrects this? I replaced mine a bit ago and it seems to have solved the problem. I found them on ebay
Alex
1976 Eldorado Convertible - Labor of Love
winger888
Thanks Alex.  :)
I just typed "plastic grommets cadillac visors" and found them on ebay. There is a bunch of companies offering them. Never thought about it
76 Eldorado Bicentennial
79 Lincoln Town Car Collectors Series
Mike Shawgo
KWirth,
I smiled when you said you broke the drill bit.  I was doing the same thing on my 74 Eldo convertible years ago, and broke the drill bit--but, problem fixed!
