A/C Dash Vent Remover Tool
Started by Joel Den Haan #21586, December 26, 2006, 06:07:33 PM
I wonder if Remover and Installer Tool J-24612-01 is still available out there, or if somebody has come up with a reasonable substitute for removing the dash A/C grilles on my 78 6D69?  Ive broken a number of the fins already, have some good replacements available, but dont want to break them on installation!
Thanks!
Joel Den Haan
Ev Marabian
Joel!    The tool that you were inquiring about should still be available from Kent-Moore who provides tools for GM autos.  The one you need is as you stated J-24612-01 A/C Louvre Remover and should still be available from SPX KENT-MOORE.  Their telephone number is 1-800-468-6657 for you to order.  Give them a call because you are right it is easy to break the louvre during installation, etc.  Good Luck!    Ev Marabian CLC # 17806
Frank #12944
i just checked, available to be shipped late January but they cost $225.00 each....
OK so if they are $225 US, I wonder if anyone out there has figured out an alternative method?  Im thinking of surgical tools, special needlenose pliers, etc. etc.?
Ev Marabian CLC#17806
Joel   You got to be crazy if you pay $225.00 for that tool.  My friend made this tool for my 76 CDV back a few years ago and all it is is a piece of spring steel worth no more than $20. or $25.  Be certain to call Kent-Moore and ask for one of their catalogs so you can see the design of this tool.  EAM
Barry M. Wheeler #2189
Hi, I use a piece of thin plastic to slip between the end and the housing, and then pry the plunger out with a small screwdriver. It never seems to work the same way twice, but if you are careful, you wont break anything. The price quoted is unreal...
denise 20352
  I just use a small screwdriver and slip the ends out one at a time.  There is a picture of the special tool in the FSM, basically just a wishbone-shaped strap with a notch in each end so that you can get both pins at once.
-denise
Joel Den Haan
Quote from: denise 20352I just use a small screwdriver and slip the ends out one at a time.  There is a picture of the special tool in the FSM, basically just a wishbone-shaped strap with a notch in each end so that you can get both pins at once.
-denise
Thanks everyone for your help on this.  Ill see if I can make a tool out of spring steel, or be in touch with the supplier.  The use of a screwdriver to remove these vents is how I broke them in the first place!  So, I guess Im less skilled than some of the rest of you....
Joel Den Haan.
denise 20352
    Did you notice the little slots in the pins that go outward and hold the vents?  The pins are just inside the ends of the vents.  That is where you put the screwdriver, in that little slot, and you have to ease the pin back gently, just enough to be able to move the vent.  It has a plastic spring, though, and  it may break whether you use the tool or not. If you can get the index finger of your other hand in there to help hold the pin, that is helpful.  Then you move the vent just 1/4 or so in or out (it may only be able to move in), just enough to keep the pin out of the hole, while you go get the other one.  Sometimes the first one slips back in there and you have to go back and forth, so it takes patience.  Then you turn the vent up or down, kind of cock it so that one end comes out first, hold your lower lip to the side and stick out your tongue in sort of an evil,  frowning grimace, and hope for the best.
    While you have the vent out, you will probably see that the piece of foam weatherstrip that was stuck on there is almost gone.  This is what gives you the friction to make your vents stay where you adjust them.  Replacing this is one of those details that gives you that new car feel again.  You can use weatherstrip, but I like to cut a thin piece of hi-density foam with an electric knife, and glue it on with weatherstrip adhesive.
   Dont feel bad about breaking them.  Weve all done it, and you can usually find replacement vents on Ebay.
-denise
Rhino 21150
If you have a trucking company in town they probably have some steel banding material for shipping crates that they want to get rid of. This stuff is VERY useful. You can also make Slim Jims, or door lock poppers. I got some at the local newspaper printing plant, they were happy to be rid of it.
You can cut this stuff with snips and it bends quite easily with pliers. It is just stiff enough to do this job.
AALZERO
hey there this is Al zero!
I'd like to thank everyone for their suggestions I haven't had a chance to work on the Cadillac lately but I will get to it soon but thanks for the information.
Bob Hoffmann CLC#96
This topic is TEN years old!!!
and this
http://www.ebay.com/itm/271419167622
is the tool on e-bay .  Someone got their decimal place wrong
The secret is don't try to pry both tabs and pull the vent out.
Gently pry one tab and push that side into the dash. The other side will pop free and then you pull the vent out towards you.
This is the Caristo method and it works very well.
EAM 17806
Quote from: Bob Hoffmann CLC#96 on April 04, 2017, 11:35:45 PMThis topic is TEN years old!!!
SO WHAT!  Many members are still quite interested in figuring out how to buy this tool (whitin reason) or just how to make one.  Just what seems to be your problem?   EAM
Ev Marabian
1976 Cadillac Coupe DeVille, 1989 Chevrolet Caprice Classic, 1990 Pontiac Bonneville and 1996 Buick Skylark
this is the Kent Moore tool
Big Fins
It's now 15 years old. And Ev, if you haven't figured Bob out by now, you never will. He shoots from the hip.
Current:
Past and much missed:
1977 Brougham de Elegance
1972 Fleetwood Brougham
1971 Sedan de Ville
1970 de Ville Convertible
1969 Fleetwood Brougham
1969 Sedan de Ville
1959 Sedan deVille
