1940 LaSalle cabin air inlet parts?
Started by Poncholover, September 30, 2022, 08:22:15 PM
Poncholover
The outside "scoop" is present as is the inside portion but there needs to be something to connect the two. Does anyone have a photo of what I should be looking for here?
Flattie Caddy
Brad Ipsen CLC #737
The base frame and mounting bolts are missing.  The base frame is pot metal and fragile.  I have an extra, but it is broken.  It may be possible to make it with steel or brass.  More info contact brad@ipsengarage.com
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
1940 Cadillac 60S Limo
Poncholover
Thanks You kindly for the excellent photos.
The solution will likely be to fabri-cobble something more practical.
Flattie Caddy
