Cadillac 0 - 60 Times: 1949 - 1969
Started by Eric DeVirgilis CLC# 8621, May 23, 2023, 03:39:09 PM
Acceleration measurements complied from various automotive magazines for new cars. I also wanted to include MPG figures but there was too much inconsistency between the way fuel economy was reported to be meaningful.
1949: 15.8 seconds
1950: *
1951: 16.6
1952: 13.2
1953: 12.8
1954: 11.4
1955: 11.2
1956: 10.7
1957: 10.6
1958: 13.3 (reg) 12.4 (premium) Popular Mechanics; 11.0 Motor Life
1959: 10.3
1960: 10.7
1961: 11.0
1962: 11.0
1963: 10.4
1964: 8.5 (start of THM trans)
1965: 9.2
1966: 11.1
1967: *
1968: *
1969: 9.4
* Test data N/A.
Test samples up to 1959 usually were not equipped with air; all were equipped with air 1960 and later.
So I guess my 3.6 seconds in my 73 might be considered an improvement? Stock it was about 8 seconds
Director Modified Chapter CLC
10.7 according to several online sources.
V63
1957 - 1958 seems a rather dramatic negative change given the same drive train save for lighter rear springs?  (Leaf vs coil)
1/8 th mil.
e in 9.6 at 76 MPH means 0-60 just about 8 seconds
jagbuxx #12944
Very interesting, thanks for posting!
Frank Burns #12944
76 Coupe d'Elegance EFI Galloway Green Firemist
70 deVille Convert San Mateo Red
61 Coupe Deville Bristol Blue
41 Series 61 Deluxe Coupe 6127D Black
08 STS 3.6 1SC  Thunder Gray
16 GTI Gray
03 T-Bird Black
16 Grand Cherokee Summit, Granite
19 Tiffin Phaeton 40AH
07 Corvette Blue
20 MB S450 White
"Whatever the occasion, there
is no better way to arrive than in a Cadillac.
Lexi
A lot of that depends on the axle ratio.  The
ratio would generally change with the TH400
torque converter trans.  Quarter mile speeds
would be more indicative of the power to weight
ratio.
Later years (running unleaded) would be interesting.
Bruce Roe
Dave CLC#16900
Would be interesting what the different engine options did in the 50s (single vs. dual or tri-carbs).  Most of the Eldorado packages also had a bigger gear if I recall correctly.
Dave CLC#16900
1956 C 6237SDX ELS
1975 C 6CD47 CDV
Jon S
With my stopwatch my 1958 does 0 to 60 in 10.2 seconds.  I am also confused by the large difference between the 1957 and 1958 0 to 60 times since both cars are very similar.
Jon
1958 Cadillac Sedan De Ville
1981 Corvette
2004 Mustang GT
V63
#10
I would resolve that there is a misfire in that particular record. 1957-58 additionally your own confirmation, are effectively that the models  should have the same results ....of coarse,  all things being equal (AC, model and carburation ect)
#11
I checked again and found another road test for a 1958 Series 62 Sedan from Motor Life which puts 0 - 60 at 11.0 seconds.
The 12.4s & 13.3s timings for premium and regular fuel were reported by Popular Mechanics whose analysis and results were much more exhaustive which was also the only article to publish figures for two fuel grades. I'll amend the original post to include the other figure.
Clewisiii
I would love to see this in terms of MPG per year.  But I know is sensitive to many variables
"My interest is in the future, because I am going to spend the rest of my life there."  Charles Kettering
64\/54Cadillacking
Seems like the '64 was the fastest of the bunch. I can agree, the 64's are fast cars for their size and weight. The TH400 really does make a difference of off the line power, it's super smooth as well.
Plus the 429 has tons of torque and really pushes these cars easily.
I'm a bit surprised by the 65'a being a tad slower since they introduced the variable pitch stator in the 65-67 transmission which adds additional power to the cars.
Currently Rides:
1964 Sedan Deville
1954 Cadillac Fleetwood 60 Special
1979 Lincoln Mark V Cartier Designer Series
2007 Lexus LS 460L (extended wheelbase edition)
Previous Rides:
1987 Brougham D' Elegance
1994 Fleetwood Bro
1972 Sedan Deville
1968 Coupe Deville
1961 Lincoln Continental
1993 Lincoln Town Car Signature Series
1978 Lincoln Continental ( R.I.P.) 1978-2024 😞
V63
I remember,  1964 models...
 motor trend ?
stated
 "never seen anything so big go so fast!!!"
wrefakis
68 time was in motor trend
69-70 times mean nothing as with the correct 97+ octane fuel 0-60 involves almost 8 seconds of wheelspin,i spun the tires yesterday in black convert at 30% throttle and it has posi rear and radials
30-50 times more indicative of power,and at 30 in high gear if you floor it even then you get a bit of wheel spin
Scott Nellis
   If anyone can post a 1968 time I would greatly appreciate it. I am curious what that glorious new 472 was up to.
1957 Eureka Hearse
1965 Miller-Meteor Hearse
1968 Miller-Meteor Hearse
1968 Fleetwood Brougham
1970 Superior Hearse
Quote from: Scott Nellis on May 27, 2023, 07:38:16 AMIf anyone can post a 1968 time I would greatly appreciate it. I am curious what that glorious new 472 was up to.
1969 should be similar.
Jon S
Quote from: wrefakis on May 26, 2023, 09:33:30 AM68 time was in motor trend
That's the sign of dried rubber tires
Jon
1981 Corvette
2004 Mustang GT
The 1969 was tested in Motor Trend as follows:
0 - 60 - 9.4s
1/4 mile - 16.5s @ 83.8 mph
Passing 50 - 70 mph 5.6s
Road Test magazine figures were:
0 - 60 - Not provided
1/4 mile - 17.7s @ 84 mph
Passing 50 - 70 - 6.0s
Both cars were Coupe deVilles.
