1958 transmission
Started by pozest80hd, November 27, 2022, 05:41:41 PM
pozest80hd
hi there everyone, was wondering if anyone new what sealing agent was used or should be used between transmission body and bell housing on 1957  trani's. when pulled apart there was a white type sealer between the two parts. thanks for your time and await a possible answer.  Jeff 1957 series 60
Jeff Stone
1957 Cadillac Fleetwood
2001 cadillac Eldorado
There should be just a large O ring located into the groove. Nothing else.
Harley Earl
Roger is absolutely correct.  Someone, most likely, used "Gasgacinch" or a like sealer during a previous repair.
Hoping for a Standard Trans Cimarron
1950 Series 61 Sedan - Savoy Gray
1974 Coupe de Ville - Victorian Amber Firemist
1959 Coupe de Ville - Brenton Blue
And 20 "other" Cadillacs from the 40s to the 80s
