missing a front wheel bearing dust cap
Started by 59 DIRTY RAT, November 11, 2013, 05:11:11 AM
59 DIRTY RAT
Hi Guys, does anybody sell the front wheel bearing dust cap?? I have tried looking everywhere to no avail. OR does any other cap fit?
'59 Fleetwood 75 imperial limo
'69 Corvette 540ci 755hp
'72 Suburban 454ci
Most stores carry or can get Dorman so if there is one here that will fit it should be a fairly inexpensive fix.
http://www.dormanproducts.com/gsearch.aspx?type=keyword&q=dust+cap
As a temp fix for damaged or odd sized hubs I have used a rubber plumbing drain cap and hose clamp.  Those are available in the pvc plumbing section of your favorite home / hardware store.
Gene Beaird
Although available from Doorman and Help! brand, I find that many times those units fit a little loose.  Luckily, they don't cost a lot, so if the fit is poor, you can use it to keep the dust and moisture out until you can locate one in a junk yard.
Gene Beaird,
1968 Calais
1979 Seville
Pearland, Texas
CLC Member No. 29873
M. Bankes
What year ? I've got a couple dozen parts cars and can sell you a used one. I have from 55-59
M Bankes
59 DIRTY RAT
Thanx for your help Guys,
M. Bankes, I have a 59! Only thing is that Im down under in Australia! Paying you might be a hassle? unless I can pay PayPal?
How much can I get one for? I would rather buy from you than a store but if its a hassle I fully understand
Thanx, Andy
Message me if u like.
'72 Suburban 454ci
59 DIRTY RAT
Also, TJ Hopland - which part number is the dust cap in the Doorman site? I havent measured the diameter so im not sure which one fits
Thanx
'72 Suburban 454ci
M. Bankes
Hi,
It's not a problem at all to send you one, and pay pal is fine with me. I just sent you a PM with the details,
M Bankes
59 DIRTY RAT
'72 Suburban 454ci
