As of October 1st, 2022 the CLC has reduced the annual e-membership dues to $25. Non-CLC members in the forums, time to join and experience all the other benefits? See post in the General Discussion forum for a link to the Join page
WTB 1946-1959 UPPER Horn Insulator
Started by dn010, December 12, 2022, 10:25:57 AM
dn010
I think I posted looking for this a year or two ago and ended up getting a makeshift lower insulator. Now I need the upper that is pictured in the link below. It is the insulator that requires the contact to be unsoldered, etc.
https://s.yimg.com/aah/yhst-44448601296963/1946-1959-cadillac-upper-horn-contact-insulator-6.gif
-----Dan Benedek
'81 DMC DeLorean
dn010
Mods, can you please add "Willchris21" to the scam/ban list?
-----Dan Benedek
'81 DMC DeLorean
Bobby B
Dan,
 Hi. You can easily make this from a plastic CATV bushing that they use to pass the CATV wire thru an outside wall with. You just trim it down the mushroom head and the length to match the original and it fits perfectly. Big box stores have a 2PK for under $2.00. I posted something regarding this years ago.
                 Good Luck,
                     Bobby
1968 Mustang Convertible
1973 Mustang Convertible
1969 Jaguar E-Type Roadster
1971 Datsun 240Z
1979 H-D FLH
dn010
Thanks for the heads up on that. I knew about the electrical part to fix the lower contact issue but not a CATV bushing for the top. I'll pull it apart this weekend and head to the store with some measurements.
-----Dan Benedek
'81 DMC DeLorean
Dave Ventresca
Dan, I have a 53 cadillac. my horns don't have any parts like that pictured. are you sure they are for all cars 46-59?Dave
dn010
This piece is not part of the actual horn itself. Rather, it is an insulator that drops into the top of the inner steering shaft and insulates the horn wire contact from the shaft. Without it, the horn wire would touch the steering shaft and the horn would sound at all times. Only way to see it is to take the horn ring off and it is in the center of the shaft, under the horn contact. Kind of hard to describe without photos.
-----Dan Benedek
'81 DMC DeLorean
David King (kz78hy)
I had the terminal and insulator scanned and made for my car.  I could have more made if needed.
David King
CLC 22014  (life)
1958 Eldorado Brougham 615
1998 Deville d'Elegance
1955 Eldorado #277
1964 Studebaker Commander
2012 Volt
CLCMRC benefactor 197
