As of October 1st, 2022 the CLC has reduced the annual e-membership dues to $25. Non-CLC members in the forums, time to join and experience all the other benefits? See post in the General Discussion forum for a link to the Join page
1929 La Salle Compression
Started by NH LaSalle, January 22, 2023, 02:57:53 PM
NH LaSalle
Can the valves and rings be replaced on a 1929 La Salle without removing the engine from the car?
harry s
The tricky thing about replacing the rings is the pistons have to be removed from the bottom of the engine. The crankshaft must be turned for each removal. I would say it can be done with the engine in the car but would be a lot easier if it were removed.   Harry
Harry Scott 4195
1941 6733
1948 6267X
2011 DTS Platinum
DaveZ
Yes. We have a 32 and I believe for that part they are the same. Pistons can be removed from the bottom, but to put them back in you need to push the rod up from the bottom and then put the piston on using a ring compressor and slide it back down. The wrist pins should go in one direction. Read the manual. LONG screwdriver to tighten the wrist pin set screw.
David Zitzmann
1932 345B
houseboats1
Without a doute just pull the engine out. If tour engine needs rings it could need cylinder boring, seals etc. If it needs valves it will need work on the valve seats as well. To do it the correct way its engine out.
DaveZ
You only need to take the engine out if you need to do the rod and main bearings. To do only the rings and valves only the blocks need to come off. Depending on the 'why" it may be a good idea to rebuild the whole engine:-) In that case engine should come out.
David Zitzmann
1932 345B
