As of October 1st, 2022 the CLC has reduced the annual e-membership dues to $25. Non-CLC members in the forums, time to join and experience all the other benefits? See post in the General Discussion forum for a link to the Join page
1951 series 62 brake shoes
Started by Davidcamper, January 23, 2023, 06:38:29 PM
Davidcamper
I have run into a problem. It seems the 1951 series 62 has unique brake shoes and are impossible to find if my research is correct.Anyone own a 1951 that can verify if 1950 shoes will fit? I have a set of 1950 from caddydaddy on the way but my fear is they will not fit. I will know soon.
I do know that all the parts houses has 419s listed for 1951 and they certainly do not fit as they are 12" shoes and my 51 is 11-2 1/2".
Any info would be appreciated.
Thnx,
David
Jay Friedman
According to my 1935-55 parts manual, 1950 and 51 have the same is 11-2 1/2" brake shoes front and rear.
1949 Cadillac 6107 Club Coupe
Decatur, Georgia
CLC # 3210, since 1984
Dave Ventresca
I just did a brake job on a 51 fleetwood. had to take shoes to NAPA to be relined. nothing available from parts houses. Dave
Jay Friedman
Ultimately, having the shoes relined is frequently the easiest solution.
However, here in Atlanta the last time I did my brakes the only shop I could find to do that was a firm that supplied relined shoes for large trucks.  They relined my original '49 shoes and arced the shoes to my drums. So far, so good, but then when I installed everything it took a lot more pedal pressure to stop the car than before. It turned out that the lining they used had less friction if that's the right word.  It was suitable on large heavy trucks, but not on a much lighter '49 Cad. In the end, I bought on ebay for a reasonable cost a set of shoes that I suspect were made in China, but was pleased to find they stop my '49 perfectly with normal pedal pressure.
Decatur, Georgia
White Post Restorations in VA. I think, have done relines for me that worked well.  Give them a call.
Davidcamper
Thanks everyone. All so helpful. Yes, the book says 50 and 51 are the same but...... I'm being told they are not. I'm hearing in 1951 Cadillac changed something on the crescent shape at the top of the shoe in order to make the self adjuster work better.... It didn't work well in the real world so in 52 cadillac changed the shape back but went to 12" shoes from 11".
I will see very soon as caddy daddy is sending me a set of 1950s that's in the mail.
If it doesn't work I will look into the re-lining. I'm going to check with White Post as Dave mentions.
Keep you posted.
Quote from: Davidcamper on January 24, 2023, 06:16:16 PMI'm hearing in 1951 Cadillac changed something on the crescent shape at the top of the shoe in order to make the self adjuster work better....
Self adjuster on a 1951 car? I believe it came in 1961 on Cadillac cars...
Self adjusting brakes with Cadillac came mainstream in 1960.
Jay, poses an interesting question, what is the correct lining(friction) material for this era?
There's bonded and rivets shoes, so what are these?
I was involved in a project to relocate brake resin production and it's a witches brew type operation.  I doubt anyone can resolve this without a Wagner, Raybestos, or other manufacturer know-how/documents.
There's a few reliners out there, maybe pays to calls around and ask what lining they use?   Rather than take what one can get.
I know the long life ceramics don't work well on the vehicles not designed for it.  They sold me some once and I had to replace ASAP.  They get to/operate at higher temperatures.
Davidcamper
I suspect I'm using the wrong terminology. Self adjusters may not be what I'm attempting to describe. Here is what my book states "The braking system on 1951 Cadillac cars is basically the same as that used on 1950 Cadillac cars with the exception of changes in the stoplight switch and in the backing plates on certain models". When I compare the shoes on 50 and 51 the crescent shape at the top is different.
