Reminder to members, please access your profile and make sure that you have created a secret question and answer. This is required to enable the system to send you a Reset Password email if you forget your password.
Spring and lever for kickdown switch 67 deville
Started by Cadillac1967inthenorth, January 25, 2023, 02:47:54 PM
Hey, im looking for spring and lever for the kickdown switch for my 67 Cadillac deville hardtop. Im not shure if its the same lever and spring as in 1968.
Gustav
1967 is a one of a kind. I've got a few 67 switches in parts I'll check and see if I've got what you are asking for.
Quote from: "Cadillac Kid" Greg Surfas 15364 on January 25, 2023, 10:42:52 PM1967 is a one of a kind. I've got a few 67 switches in parts I'll check and see if I've got what you are asking for.
Thank you.
Switch is ok, I tested it. I suppose someone removed the card and didnt care for the spring and lever
cadillactim
The diagram is for a 1968. The 1967 did not used the spring or lever. Peg went into square hole in carb linkage.
Tim
Tim Groves
