Video: 1968 Cadillac Assembly Line
Started by Eric DeVirgilis CLC# 8621, March 09, 2023, 10:51:04 AM
badpoints
It is odd that they show a rear end with leaf springs.
Quote from: badpoints on March 09, 2023, 11:16:37 AMIt is odd that they show a rear end with leaf springs.
Possibly an Eldorado?
billyoung
the opening scene with the frame is an Eldorado frame and the single leaf springs with the straight thru rear axle is the clincher. The 1967 and 1968 Eldorado's were assembled on a separate assembly line at Clark, then the 1969 thru 70 Eldorado's were built in Cleveland Ohio plant ( Euclid ) that is why on the aluminum Body plate on those Eldorado's they say EUC not FWD preceding the Body Number. I hope this helps.
Age 69, Living in Gods waiting room ( Florida ) Owned over 40 Old Cadillac's from 1955's to 1990 Brougham's. Currently own a 1968 Cadillac DeVille Convertible and a 1992 Cadillac 5.7 Brougham.
