54 wheel seal replacement, which sealant around outer edge
Started by Julien Abrahams, May 19, 2023, 02:58:28 PM
Julien Abrahams
Hey guys,
Somehwere in the next week I would like to tackle replacing a rear wheel seal (that keeps the differential oil from reachting the brake drum). The shop manual states to use a sealent around the outer edge of the seal to prevent leaks. My question is: is that necessary with the modern seals, and if yes, what type of sealent is best used? Regular blue or black rtv?
Thanks in advance.
1954 Cadillac series 62
1969 Austin Healey Sprite
1979 Opel Kadett
