1948 Series 62 Pinion Seal
Started by Fredy Decker, December 02, 2022, 11:34:51 AM
Fredy Decker
I am having trouble locating a replacement pinion seal for my 1948 Convertible. It is encased in a sheet metal spacer/adaptor so as to have it located forward of the carrier about 1/2"  I think that the only way to remove the spacer/adaptor is to destroy it.  I can find a replacement seal but not the spacer/adaptor. Any advice out there.
J. Russo
Have you tried Terrill Machine in Texas?
John Russo
Fredy Decker
I have not but I will try to get in touch with them. Thanks,
Jay Friedman
1949 Cadillac 6107 Club Coupe
Decatur, Georgia
CLC # 3210, since 1984
harry s
If I'm reading this right you have or can get the seal but can't find the cup it fits in. The seals are readily available but the cups are not. The easiest way to remove the cup is to clean around the edges and spray with PB. Then remove the pinion yoke. You can then use a hammer and punch to drive the seal inward from the cup until it is free. At this point a small puller will fit with the lugs facing outward. The cup should come out without any damage.
Harry
Harry Scott 4195
1941 6733
1948 6267X
2011 DTS Platinum
Brad Ipsen CLC #737
If anyone gets really desperate for one of the cups, I have a couple, but Harry describes the method to get them out very well.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
1940 Cadillac 60S Limo
Bob Schuman
Another approach is to drill two small holes 180 degrees apart in the spacer, insert a sheet metal screw in each hole, then pull on the screws to get the spacer and seal out. Clean up and solder shut the two screw holes before reinstalling. The main objective is to remove the spacer without destroying it, because replacements are very rare.
Bob Schuman, CLC#254
1951 6137
1948 Olds 98 Custom
2020 XT6
