1953 331 non resistor distributor rotor
Started by Caddyrag67, December 02, 2022, 07:47:49 PM
Caddyrag67
I am in the process of converting my Is 1953 331 Distributor to a patronixs unit. I have read a lot of fourms stating that you need to swap over the rotor to a non resistor style or they will burn up because of the pertronix swap. I cannot find a rotor part number that will work with my distributor.  if anybody has a part number I would greatly appreciate it
Brendan Gielow
CLC Member # 31224
1952 Series 62  Convertible
1958 Eldorado Seville
1960 Coupe DeVille
1967 Coupe Deville Convertible
Joe Jensen
I purchased one for my '49 from RockAuto, Standard brand, DR306.
You can buy the cap from them as well.
Good Luck!
Joe
Dave Ventresca
just converted a 1950 cadillac to pertronix.. used the stock rotor. works perfect.Dave
Poncholover
Be certain to carry the old points & condenser in the glove box just in case.
You will eventually need them.
Flattie Caddy
Jay Friedman
Keep in mind that the same rotor was used from 1938 to 1950, but beginning in '51, and including '53, the rotor is different.
1949 Cadillac 6107 Club Coupe
Decatur, Georgia
CLC # 3210, since 1984
Caddyrag67
Brendan Gielow
CLC Member # 31224
1960 Coupe DeVille
Joe Jensen
Brendan:
The DR306 is not a resistor type.  Attached is an example of the resistor type (left side) for a '49 next to the non-resistor type (right side).
Note: as mentioned earlier the rotors shown for a '49 are not correct for your '53.
I hope that helps.
Good luck!
Joe
CadillacFanBob
Good article in Self-Starter May 2016 page 29 on ignition rotors by Johnny Washburn.
Bob
Frankfort, Illinois
