55 Power steering gearbox lube
Started by Bob Kielar, December 07, 2022, 03:06:40 PM
Bob Kielar
What is the capacity of gear lube for a 55 Cadillac power steering gearbox?
Bob Kielar
Keep Cruzin
1955 Cadillac Fleetwood
V63
I believe the whole unit utilized type A automatic transmission fluid ?
Mike Josephic CLC #3877
#2
The 1955 unit was a "hybrid" unit that had two sides, a hydraulic side that used ATF and a separate gear box that used a lubricating oil.
The fluid Cadillac called GM-4673M was used to lubricate
the gear box was the same as 80-90W (or straight 90) oil.  There is no noted capacity for this unit in the literature.  The only advice for refill is to fill to the top of the filler plug opening.
1955 Cadillac Eldorado
1973 Cadillac Eldorado
1995 Cadillac Seville
2004 Escalade
2011 Buick Lucerne CX
CLCMRC Museum Benefactor #38
64\/54Cadillacking
I recently refilled my gearbox in my 54 with gear oil and it slowly leaked out everywhere. So I've heard many people simply just injecting wheel bearing grease until it fills up the plug.
This is exactly what I did because my gearbox was bone dry. And the steering feels even smoother now.
Eventually it will need to be rebuilt with new seals to prevent leaks but for now I'm ok with how it feels.
Currently Rides:
1964 Sedan Deville
Previous Rides:
1987 Brougham D' Elegance
1994 Fleetwood Bro
1972 Sedan Deville
1968 Coupe Deville
1961 Lincoln Continental
Jim Miller
I used Penrite steering box lube suggested by Jay Friedman on both my 41 and 49. It works very well with no more seepage.
Jim Miller
1941 6219
1949 6237X
1970 CDV
2021 XT6
Past:
1991 SDV
1999 DeElegence
2006 DTS
2013 XTS
2016 SRX
Bob Kielar
Hi Jim, How much Penrite lube did you use? Also where did you purchase it from?
Bob
Keep Cruzin
Jim Miller
Bob, I cleaned out as much old lube as I could. Then filled with the Penrite. I see a bottle on Ebay for about $17. It's called Penrite Semi Fluid Steering Box Lube.
Jim
Jim Miller
1941 6219
1949 6237X
1970 CDV
2021 XT6
Past:
1991 SDV
1999 DeElegence
2006 DTS
2013 XTS
2016 SRX
Supposedly you can get it here --- https://restorationstuff.com/  Also Amazon reportedly sells it and maybe Tractor Supply.
timer2
Mine leaked out of the Pitman shaft seal. Simple inexpensive repair and hasn't leaked in 11 years.  Terry
walt chomosh #23510
Mike Baillargeon #15848
#10
Where are you guys getting the Penrite ?
I see it on eBay for $17 but shipping from Australia is $60 plus per bottle back to the states.
There was a heated discussion on another forum about whether Tractor Supply's "Super S Cotton Picker Spindle Grease 00" was just as good as the Penrite.
https://www.tractorsupply.com/tsc/product/super-s-cotton-picker-spindle-grease-00
At $5.99 a bottle at Tractor Supply, the Super S is worth a try ?
Baillargeon
#15848
Bob Kielar
Penrite Steering Box Lube/ Semi Fluid
1200w, EP, non-leaking, manual boxes OK w/yellow metal NLGI 00 Lithium Base
500 grams
Hey guys Is this the Penrite lube ?
Bob Kielar
Keep Cruzin
Jim Miller
Jim Miller
1941 6219
1949 6237X
1970 CDV
2021 XT6
Past:
1991 SDV
1999 DeElegence
2006 DTS
2013 XTS
2016 SRX
Daryl Chesterman
You can get Penrite steering box lubricant here:
     https://restorationstuff.com/shop/#fb0=27     (bottom of page 24)
Daryl Chesterman
Bob Kielar
Got my Penrite gear lube from Restoration Stuff on December 19 2022 ordered on December 14 2022. The lube/grease was $21.00 for 500 grams I purchased two the shipping was $14.21 from California to Janesville Wisconsin. Now to figure out how to get it in the fill hole any ideas?
Bob Kielar
Keep Cruzin
