NOS Cadillac parts 1960 1970s 1980s large list
Started by brian faull clc#25881, September 13, 2020, 05:33:01 PM
I have a large collection of nos Cadillac parts I am planning to start selling on Ebay. I thought I would post them here first, so if any club members are looking for something, they can get first shot at them. I catalogued what I have, and put the quantity I have of each part. I have not taken pictures of the parts yet. If anyone is interested in anything let me know which parts, and I will get you pictures and prices. Thanks, Brian. 412 952 6027.  cadillac32v@hotmail.com
1- 3633669 Gr: 1.123 Water pump rebuild kit 1968 -76 Cad
1- 25031699  or 25030988 1982 - 1987 Cadillac Cruise control solenoid valve
1-  7302385  Gr: 9.275 Cadillac A/C vacuum switch 64 - 65  exc 75 /  66 -68 all / 69 - 70 Eldo + 75 / 71 -74 Cad 75 series / 75 - 76 Fleetwood only
2-  995303 Gr: 10.352 1977 - 79 Cadillac sedan full set of 4 door edge guard trim C / B 69 Sedan
1-  996547 Gr: 10.352 1979 - 80 Cadillac E body door edge guard trim set of 2
1-  1492007 Gr: 10.352 1968 Cad coupe exc eldo RH door edge guard trim
1-  6598830  or 2724000 Gr: 15.5112 1973 -77 cad VIR ASM Kit
2-  5966079  Gr: 2.725 cad headlamp and bucket assembly  NORS
2-  5966078  Gr: 2.725 cad headlamp and bucket assembly NORS
3-  5966077  Gr: 2.725 cad headlamp and bucket assembly NORS
1- 5966547 lens 1975 -76 eldo rt or lt parking lamp lens
1-  5962299 Gr: 2.589 Lens 1970 Cad exc Eldo
3-  1496206 Gr: 10.275 1971 -73 Cad Map light assembly
1-  1609647  Gr: 1.062 1978 Cad C/D/E/Z water pump pulley exc A.I.R. / 145 amp
1-  1601405  Gr: 2.459  1973 Cad Phototube headlamp beam control mounting kit
1-  20098996 Gr: 12.187 1979 -80 Cad E body trunk lid support
1-  5959244 Gr: 2.709 plate light lens 1968 Cad all exc eldo
1-  912164 or 912822  Gr:2.700 License late lens 1974 -75 Cad exc Eldo
1-  6551220 A/C clutch drive Assm. 1977 -81 Cad with radial compressor
3-  1223351 Gr: 9.280 Valve package 1971 Cad with auto temp
2- 1222592 Gr: 8.852 Valve package Heater vac control valve  1967 -68 Cad all exc eldo and 75
3-  7308279  Gr: 8.852 Valve package a/c and heater control vac valve with 8 ports 1969 -70 Cad
4-  7930501 vacuum relay 1971 - 79 Cad all  programmer relay checking valve
1-  7297405 Gr: 9.275 a/c ambient switch and sensor Cad 1965 all exc 75 / 1966 Cad all /  1967 -70 Cad all exc Eldo
1- 8630962 Gr: 4.005 transmission overhaul kit 1978 -79 Cad all with M29 : DELCO
2- replacement 8630962 Gr: 4.005 transmission overhaul kit 1978 -79 Cad all with M29 : NORS
1- 3633831 Gr: 12.247  1973 Cad all, trunk lock and cover kit   lock cover fits Cad all 1972 -76
1- 8623061 Gr: 4.169 1964 -66 Cad TH400 transmission drum
1-  20010095 Trunk pull down motor 1977 -79 Cad C/D/K with electric comp lock
1-  9836225 Gr: 10.485 1971 - 1976 Cad sedan LF power door lock actuator assm.
1-  8791129  Gr: 10.485 1971 -1976 Cad coupe Rt power door lock actuator assm.
1-  8791128 Gr: 10.485 1971 - 1976 Cad coupe Lt power door lock actuator assm.
2-  335898 Gr: 6.164 rear bushing set 1977 -78 Cad D / Z body
1- 6466450 Power Unit 1985 -87 Cad
1-  22071780 Gr: 10.153 1974 - 76 Cadillac washer pkg 2 pulse wiper pump
1-  16047800 Gr: 9.275 Power stage 1985 - 93 Deville
1-  1487176 Gr: 0.679 Flywheel Cover 1968  - 76 Cad All exc Eldo
1-  9835516 or 9633795 Gr: 10.485  1971 - 76 Cad sedan Rt rear power door lock actuator
10-  3989344 Gr: 1.745 PCV Grommet 1976 - 79 Cad All vent pipe grommet
6-   1370748 Gr: 1.800 Oil Pressure witch 1976 Cad all with EFI
2-  9796480  Gr: 8.855  resistor 1971 -74 Cad all exc A/C blower motor heater relay
1-  1260636  Gr: 1.800  Oil Pressure Switch 1982 Cad C/ K 1982 -84 Cad Z
2-  1487137 Gr: 0.335 1967 Cadillac rocker arm retainer
1-  1492292  Gr: 1.745  1968 - 1970 Cad all LH breather / filter assembly
1-  1497150 Gr: 2.897  Lever turn signal color: saddle  1971 - 72 Cad all exc 75 without T/T exc cruise
1-  1497145 Gr: 2.897  Lever turn signal color: black  1969 - 73 Cad all exc 75 without T/T exc cruise
4-  1618842  fuel pump relay 1980 Cadillac E / K
1-  550703  Gr: 2.195  Anti theft plunger switch 1976 - 79 Cadillac all
2-  1876018  Gr: 2.181  Wiring Harness ignition distributor 1976 -77 Seville with 350
1-  3015636  Gr: 2.410  Manifold Vacuum Switch 1967 Cad Eldo + 75 series / 1968 - 1970 Cad with A/C only / 1971 -1974 Cad all / 1975 Cad all exc 75 / 1076 Cad with EFI
2-  12010793  Gr: 2.510 Diesel Probe Glow plug control sensor  Cad1982 -83 C / D / E / K / Z 84 + 85 E / K / Z
3- 7027092  Gr: 3.750  Carb choke stat coil 1967 Cad all
5-  5233720  Gr: 3.332 Nozzle assm. 1979 -81 Cad Fuel injection nozzle
1-  22502883  Gr: 3.028 Cap assembly Diesel Fuel Only  1980 Cad C / E / K w 350N
1-  25030172  Gr: 3.885 Solenoid assm. Vac / elec Cruise control Diaphragm 1972 Cad 2nd design / 1973 - 74 Cad all / 1975 - 77 Cad all
1- 1616384 Gr: 3.670  Map sensor with Harness Bendix 1980 Cadillac with 368
1- 1497579  Gr: 3.883 1971 -73 Cad Cruise control on / off switch escutcheon
1- 1494344  Gr: 3.885 Cruise control Diaphragm mounting bracket 1969 Eldo / 1970 -71 Cad all 1972 Cad 1st design
16 -  6261781 Gr: 4.345 clip 1990 - 93 Fleetwood
18 -  1494635  Gr: 5.812  front Wheel hub stud 1968 Cad with disc brake exc eldo / 1969 - 71 cad exc eldo / 1972 Cadillac 75
12- 1653249  Gr: 14.691 Fillers 1977 -78 Fleetwood / Deville door strap / door pull cover
1- box 9783762 Gr: 5.595 Pinion nut 1979 Cadillac all exc Eldo
2- 3965092 1976 - 80 Cad C/ D / K /Z front hub bearing inner seal
1- 7299453  Gr: 8.852 1967 -68 Cadillac heater switch
1- 1222595   Gr: 8.852 Switch Hi / Fog / Ice 1967 - 68 Cad all
2- 1222593  Gr: 8.852  Heater Valve with 6 ports 1967 -68 Eldo
1- 3905776 Gr: 8.857 heater blower fan Cad 59 -70
1- 3012944  Gr: 9.195 A/c dehydrator receiver dryer 1968 Cad all 1968 -72 Eldo
1- 7297405  Gr: 9.275 Ambient sensor switch in air inlet front 1965 cad all exc 75 / 1966 Cad all / 1967 -70 Cad all exc eldo
3- 1611357  Gr: 9.277 Relay 977 -80 Cad C / D / Z ATC blower relay
1- 1604115  Gr: 9.277 Relay  1974 - 75 Cad all Blower Relay
1- 1610029  Gr: 9.647 Relay 1976 -early 1977 Cad antenna relay
1- 1611369  Gr: 9.647  Relay  1978 -79 Cad power antenna relay
2- 20006218  Gr: 10.710  Supt assm. 1977 - 79 Cad C / D /  1979 Cad K Front door window bumper
7- 1493632  Gr: 10.275  Lamp assm. 1969 -70 Cadillac courtesy / map lens
1-  4818080  Gr: 10.266 Glove lock 1963 -65 Cad All
2- 3991767  Gr: 10.266  Case + rotor lock 1968 -75 Cad all glove lock case
1-  1497180  Gr: 10.230  1978 Cadillac E Retainer I.P. Cover to W.S. Frame
1- 1610798  Gr:  10.275  Map light lamp with switch Cadillac 1977 - 78 C / D / Z
1-  9849686  Gr: 12.242 Lock assm. Trunk Lid Cadillac 1976 C / D / E / K 1977 -78 Cad E / K
1- 7691695  Gr: 12.812  Brougham Script Emblem 1965 -75 Roof panel
1- 3633187 Gr: 12.812  Cadillac Wreath emblem 1964 -65 Fleetwood 60 S roof side and 1967 Eldo
1- 20146995 or 20155415  Mirror Switch 1979 -80 Cadillac C /D / E / K /  1979 - 84 Deville 1979 - 85 Eldo 1982 -92 Fltwd Brougham 4 dr / 1982 - 85 Fltwd 2 dr
2- 830282  or 1892265  harness module to coil 1976 - 77 Cadillac all exc K
1- 1993688  Neutral Safety Switch # 688 1965 -1966 Cadillac
11- 18001228  or  18005442 Gr: 4.667  Brake caliper repair / seal  kit 1976 - 78 Cad E with rear disc /  1977-79 Cad C / K with rear disc
1-  18001856 or 18005447  Gr: 4.668  Brake caliper piston LH 1977 - 78 Cad C with rear disc / 1977 -79 Cad K with rear disc
1- 18001857  or  18005448  Gr: 4.668  Brake Caliper Piston 1977 -78 Cad K with rear disc
3- 5474509  Gr: 4.650 Caliper bolt (1 of 3 not in box)
3- 9806723  Gr: 10.466 1976 -79 Cad Front upper and lower hinge pin
2- 1465408 1976 - 79  Cad all 472 / 500 valve spring / 1980 Cad all 368 / Cad 1982 -83 368
1- 907998 #7503-1 ball bearing 1976 - 77 Cad all generator drive end
1- 9436831 Cadillac 1978 - 1980 generator bushing
2-  20003765  Gr: 10.450  Hinge 1977 -79 Cadillac C  /  1977 -80 Cad D Rh hinge body side
1- 5695827  1963 -1967 Tie rod end all exc eldorado
1- 7815851  U joint bearing package 1976 -79 Cad all exc E body / 1980 Cad C body/ 1982 - 83 Cad C , D / 1982 - 1984 Cad Z / 1991 -92 Cad Armored body (B05)
2- 1497969 or 3986982 Gr: 7.632 Spare tire hold down 1976 Cadillac C , K
1- 7818453 or 5695787 Ring and rotor vane Kit A-6 Power steering gear rotor vane 1976 Cad all exc K / 1977 - 1978 Cad
1- 587988 Gr: 8.826 U bolt Jack bracket / retainer 1976 Cadillac D
1- 782 9515 or 07829515 Gr 6.525 Bolt intershaft steering gear shaft 1979 Cad all
1- 7827028 Act assm. / actuator dimmer switch rod 1982-83 Cad C, D  T+T /1982 -86 Cad E, K  T+T
2- 7812118 or 5668547 Tie rod adjuster tube 1976 Cadillac all exc K
1- 3979975 Gr 8.080Hood latch release cable to latch clamp 1971 - 1973 Cad all
1- 1609645 Gr: 8.024 Hood bumper adjuster rear 1976 Cad C, D, E, Z
4- 478282 or 1261228 Gr: 12.243 Trunk release switch 1979 Cad C, D, K    1980 -82 C, D
1- 3634390 Gr: 1.303 1977 -79 Cad stand up hood ornament
1- 3633187 or 7643400 Gr: 12.812 emblem kit , roof crest 1976 -78 Cad roof crest / 1975 -78 Eldo roof crest
1- 7691695 Gr: 12.612 1965 -75 Brougham script, roof emblem
1- 9834649 Gr: 12.116 Calais Script 1976 Calais emblem
1- 22020003 Gr: 9.647 Power antenna escutcheon 1979 -81 Eldorado / 1980 -81 Seville
1- 1497094 Gr: 2.485 1971 - 73 Eldorado Sentinel knob
3- 1602979 Gr: 2.846 lever Chrome twilight sentinel selector knob  1976 Cad all / 1977 -78 Cad E, K with guidematic sentinel / 1979 K with Sentinel
1- 9634606 Gr: 12.182  1976 -1979 Seville Trunk lock cover Emblem (Silver)
2- 7805675 Gr: 2.895 Turn signal switch 1967 -68 Cadillac Boyne non T+T
5- 3633788 Gr: 2.575  Hazard switch button 1976 -77 Cad all
1- 478282  Gr: 12.243 Trunk release switch green button 1978 Cad C, D, E, K / 1979 Cad C, D, K 1980 Cad C, D
4- 22009703 Antenna Tip Finial 1977 -80 Cad E with cb / 1978 -1980 K with cb / 1979 Cad C, D, Z
1- 1613854 Gr: 2.897 Turn signal lever with cruise 1978 Cad C, D, E, K Dark grey
1- 6466767 Gr: 2.897 Lever turn signal with cruise 1977 -79 Cadillac C , D, E, K
1- 1494544 Gr: 2.897 Lever turn signal with cruise 1969 -70 Cad without T+T
1- 1612400 or 646767 or 1613850 Gr: 2.897 Turn signal lever with cruise 1977 -79 cadillac C, D, E, K with cruise
3- 1611228 or 1494508 Gr: 8.024 Adj bumper hood to latch bar 1976 Cad C, D, E, Z  /1977 - 78 Cad E
8- 4565591 Gr: 10.587 Bumper Front + rear Door lock pillar upper + lower door side 1976 -80 Cad C, D, E, K
1- 7803820 Power steering pump reservoir cap 1967 - 75 Cad all
1- 6432460 Fuel Gauge 1978 Cad C, D with fuel economy digital radio display / 1979 Cad C, D, Z, with econ indicator
2- 1703469 Gr: 10.560 ferrule assembly 1984 Cad E, K front and rear lock rod ferrule
1- 1600392 Gr: 4.075 Switch 1972 Cad exc Eldo speed controlled spark switch with 3.15 to 1 ratio
1- 385283 Gr: 1.745 Grommet 1976 -79 Cad all 350 BR / 1980 Cad E, K 350 -8 grommet vent valve to valve cover
1- 20011109 Gr: 12.243 trunk, rear compartment lid pull down housing 1979 Cad E / 1977- 79 Cad C, D, K
1- 1237150 Gr: 7.346 air suspension tubing kit 1976 -77 Cad all with auto level suspension
1- 9632429 Gr: 10.529 Door handle button 1976 Cad C, D, E, K front door handle button / 1969 -70 Cad 75 series / 1974 -75 Cad all
1- 8904251 or 8913510 Gr: 2.580 Vigilite assembly ( fiber optic indicator) 1971 -1974 Eldorado Left hand conductor with lens headlamp/ parking lamp
1- 1611860 Gr: 5.871 Wheel disc, colored insert 1977 Cad CB/DW DLPB2 Saffron (67L) 9" Dia
2- 1611839 Gr: 5.871 Wheel disc, hubcap colored insert 1977 Cad E with deluxe (PB2) Maderia Maroon (79L) 9 7/8"
1- 1611835 Gr: 5.871 Wheel cover colored insert 1977 Cad E w/dlx (PB2) Saffron (67L) 9 7/8" diameter
1- 587988 Gr: 8.820 Bolt Jack bolt / bracket 1976 Cad D hold down bracket
4- 1602987 Gr: 2.847 Sentinel control lens bezel 1976 Cad all exc K / 1977 -78 Cadillac E with sentinel 1974 -75 Cad all
1- 3633968 Gr: 8.055 Hood ornament base 1975 - 1976 Cad C
1- 3633968 Gr: 8.055 Hood ornament base 1975 -1976 Cad C (no package)
1- 9832197 Gr: 10.136 side mirror base gasket Rt or Lt 1976 -77 Cad C, D, E / 1971-75 Cad all / 1978 -79 Cad E with chrome mirror (DF3) / 1982 Cad E with illuminated thermometer
1- 1254990 Gr: 10.275 Switch glove box 1976 - 80 Cad all
1- 1244006 Gr: 10.275 Switch glove box 1982 -83 Cad C, D  / 1982 -85 Cad D, E, K / 1982-84 Cad Z
1- 1604171 Gr: 2.897 Lever turn signal 1976 Cad C, E with ACRS Exc T+T / cruise
1- 20208455 Gr: 12.182 Emblem, wreath 19080 Cad Cb, D Trunk lid wreath
1- 9821293 Gr: 13.090 Vigilite assembly (fiber optics)  1971 -72 Eldo conv. conductor rear stop lamp and signal lamp
1- 20000908 Gr: 13.090 Wire assembly 1977 Cad C, D w electronic compartment lid trunk release
1- 12004092 Gr: 2.584 Lamp socket 1976 - 79 Cad C, D, E, K Thermometer socket  / 1978 Cad C, D, E socket Lt  rearview mirror / 1982 -83 Cad C, D, E Thermometer socket
2- 587989 Gr: 8.820 Jack hold down bracket 1976 Cad D ( one has no label)
1- 2621703 or 18004912 Gr: 4.665 Brake caliper Left 1974 -75 Cad exc Eldo
2- 124421 Gr: 4.133 Dipstick oil Transmission 1976 Cad K / 1977 -79 Cad C, D, K, Z
1- 20021572 or 20085600 Gr: 10.186 Bracket 1977 -80 Cad C, D rt hand reinforcement Qrtr panel at mirror
4- 7815851 U joint bearing kit 1976- 79 Cad all exc E / 1980 Cad C / 1982 -83 Cad D / 1982 -82 Cad Z / 1982 -83 Cad C (4.1-4, 350m)
1- 1603191 Gr: 12.009 Retainer ashtray 1976 Cad C, D, E, Z (exc ACRS) 1977- 78 Cad E drawer ashtray reinforcement
1- 1610219 Gr: 2.468 Knob 1977 -80 Cad C/D with guidematic sentinel Knob / switch with rod
1- 12337519 Water pump 1982 -83 Cad C / 1982 -85 Cad K / 1984 -85 Cad D (350n) / 1986 -90 Cad (307Y) / 1986 -90 Cad D armored body
1- 1970548 Armature for generator 1976 -77 Cad C, D, E, Z / 1978 -80 Cad All exc (350n)
1- 1707210 Gr: 10.485 Door lock actuator 1971 -76 Cad rt rear door lock actuator
1- 995911 Gr: 2.485 Twilight Sentinel assembly 1978 -80 Cad C, D
2- 3965092 Gr: 6.326 1982 -83 Cad C, D front wheel bearing inner seal / 1982 -84 Cad Z front wheel bearing inner seal
1- 563565 Gr: 4.037 Transmission control rod bushing 1979 -80 Cad E / 1980 Cad K
1- 3633374 Gr: 3.750 1962 - 1963 Cad Choke housing for Carter Carburetor
That’s quite a list Brian. You might save yourself a lot of time if you could post your prices for these items
D DOWNARD
For what year? I know I do not have any complete nos antennas. I have some used ones, and some nos antenna parts. Thanks, Brian.
Tony clc#24130
Hi Brian, I am interested in some of the parts on your list and have some questions on others. I will private message you with contact info.
Erik
Am looking for a 1962 Deville oil dipstick tube, do you have any?
Erik D.
TD Alex
Hello, price for:   7297405  Gr: 9.275 Ambient sensor switch in air inlet front 1965 cad all exc 75 / 1966 Cad all / 1967 -70 Cad all exc eldo
also a red lens cover interior door for '67 cad?
The big one:  short or long block for 429 ci Just found out I have a bad bearing on crank and have damaged rod/cylinder
Look forward to your reply, Trent
1967 Sedan DeVille
2007 Jaguar XK Conv
1998 Land Rover Range Rover
1992 Alfa Romeo 164LS
1989 Alfa Romeo Spider
1985 Cadillac Eldorado
1972 Chevorlet Caprice Classic Convertable
1972 Buick Electra Custom Limited
1970 1/2 Volkswagon Karmen Ghia Convertable
1967 Ford LTD
1967 Volkswagon Micro Bus step thru
1965 Volkswago Fastback
CADILLACNUT
HELLO BRIAN WOULD YOU HAVE AN ANTENNA FOR A 1977 CADILLAC ELDORADO WITH C/B THANK YOU
guyrobert
Are either of these the light grey color?
Thanks Robert
1979 Fleetwood Brougham d'Elegance
1979 Coupe De Ville Phaeton
1957 Eldorado Biarritz
Robert Simpson
ALAIN
Hello Brian,
Would you have one high pressure fuel pump for a Seville 1978 (EFI, 350, gas) in stock ?
Would be for shipping to France.
And/or do you or anyone know what should be the debit capacity for this pump ?
Thank you by advance,
Alain
Alain
SEVILLE 1978 EFI 350 rocket
Cape Cod Fleetwood
LOL!
Anyone else notice this OP is almost 3 years old?
The Past -
1996 Deville Concours
1981 Coupe De Ville (8-6-4)
1976 Sedan De Ville
1975 Sedan De Ville
