'78 Biaritz, needs engine work, looks good, NOT MINE
Started by mgbeda, March 28, 2022, 03:13:58 PM
mgbeda
Saw this and thought if I had more time and less wife this would make an ideal project.  Looks very clean inside and out.  Of course you have to be able to pull the engine, but I'd rather do that than body work or upholstery.  Check out the option list, too!  $4500 near L.A.
https://ventura.craigslist.org/cto/d/thousand-oaks-1978-cadillac-eldorado/7458407406.html
-mB
-Mike Beda
CLC #24610
1976 Sedan DeVille (Bessie)
Bob Hoffmann CLC#96
Eric DeVirgilis CLC# 8621
Not insects. It looks like the dye is peeling from the leather for some strange reason.
Big Fins
I just wonder when people are going to be able to spell 'brakes', instead of 'breaks' and disc over disk. Are public schools really that bad these days?
Current:
Past and much missed:
1977 Brougham de Elegance
1972 Fleetwood Brougham
1971 Sedan de Ville
1970 de Ville Convertible
1969 Fleetwood Brougham
1969 Sedan de Ville
1959 Sedan deVille
James Landi
"I just wonder when people are going to be able to spell 'brakes', instead of 'breaks' and disc over disk. Are public schools really that bad these days?"
  ...and more pointedly, how does ones destroy a "crank bearing" in one of these very durable engines?
Bryan J Moran
There are too many low mileage 75-78 Eldorados for reasonable prices to take any risk on a project.
CLC 35000 in number only
James Landi
Bryan's comment is certainly a most worthy of consideration, but I'm thinking the present owner could be hearing a collapsed lifter rather than "a bad main bearing."  Those of us "older folks" know how horrible a stuck lifter can sound.   If it were my car, I'd perform an oil pressure test.   I'm thinking most contemporary mechanics would err on the side of caution rather than suggest what may be a minor issue.   James
Big Fins
Look at The Ark. We all questioned the wiped out thrust bearing in the engine. Bad castings, a plugged oil orifice to the bearing just for a little while, anything can happen. But, dropping the oil pan for an inspection is a moot point on these cars, when pulling the units out is about the same.
Current:
1971 Sedan de Ville
1969 Sedan de Ville
1959 Sedan deVille
