'75 Eldorado Fuel Efficiency Switch/Relay
Started by benji808, June 07, 2022, 08:38:34 PM
benji808
Interested in trying a new one. Let me know what you got!  :)
Big Fins
Take the old one out, check that it holds vacuum. Then see if the continuity is switched under harder vacuum. I sprayed DeOxit contact cleaner onto the contacts of mine and the plug connections and it works as it's supposed to.
Current:
Past and much missed:
1977 Brougham de Elegance
1972 Fleetwood Brougham
1971 Sedan de Ville
1970 de Ville Convertible
1969 Fleetwood Brougham
1969 Sedan de Ville
1959 Sedan deVille
benji808
benji808
No longer need the part - took mine off, sprayed contact cleaner, messed around with the screws and attempted to bench test it, put it back on and it works now!! If I had to put money on it I would bet that the ground nut onto the firewall bolt was just a bit lose. lol. Thanks John for the recommendation!
Big Fins
Always go for the cheaper, easy way to repair things before breaking the bank.
Current:
1971 Sedan de Ville
1969 Sedan de Ville
1959 Sedan deVille
