1961 Cadillac no dash lights on. Advice appreciated
Started by 62eldofan, June 26, 2022, 07:24:18 PM
62eldofan
Dash lights not working on my 1961 Cadillac convertible. Advice appreciated.
Would suspect headlight switch.  Part of the headlight switch function, when turned left or right, is to increase/decrease the dash light bulbs' brightness.  That part of the switch is subject to fatal wear and/or breaking in two.  If that is an original switch, its dashboard light life span has exceeded most, or has been used little.  Sometimes they can be repaired, depending on the failure mode, often it means a new switch.  There may be those here that can fix that troublesome part of the headlight switch.
David Greenburg
There are several places that can rebuild headlight switches.  Among others, McVey's does it, and I think Cadillac Tim might do it as well.
David Greenburg
'60 Eldorado Seville
'61 Fleetwood Sixty Special
Jeff Rosansky CLC #28373
I would rotate the dimmer about 50 times. I did this and it seemed to clean the contacts. It works now.
Jeff R
Jeff Rosansky
CLC #28373
1970 Coupe DeVille (Big Red)
1955 Series 62 (Baby Blue)
Dad's new 1979 Coupe DeVille
Michael Petti
I had the same issue on my 60. The rheostat had deteriorated beyond repair. Replaced it and it solved the problem.  In some cases, it can be cleaned. Either solution requires removing it which can be done by loosening the screws holding the switch together and sliding it out, not disassembling the whole thing. You will need a tool to remove the switch. I think O.P.G.I has it.
Poncholover
I have a couple on the shelf, where are you located?
Flattie Caddy
