hard brake pedal
Started by smokeytires, March 30, 2023, 02:10:57 PM
smokeytires
hello I have a question regarding hard brake pedal on a 1956 eldorado.this car belong to my neighbor.brakes were working fine until he went low on fluid. after bleeding system.he now has a hard brake pedal.has plenty of vacuum.any thoughts on this situation.deeply appreciate it. thanks
Mike Josephic CLC #3877
When he bled the system did he follow the procedure in the
shop manual?  I'm not sure about the '56 but for a 1955
with Hydrovac you must first start with the booster and
do those fittings first in order, then the rear and front
fittings as usual.
The 1956 cars, as far as I know, all had Treadle-Vac which I
have no information on.
1955 Cadillac Eldorado
1973 Cadillac Eldorado
1995 Cadillac Seville
2004 Escalade
2011 Buick Lucerne CX
CLCMRC Museum Benefactor #38
Cadillac Jack 82
I know that my 55 seems a bit stiff as compared to other makes and models of that era.  Could also be hardening of the rubber components/seals too.
Tim
CLC Member #30850
1959 Cadillac CDV "Shelley"
1964 Cadillac SDV "Rosalie"
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1955 Packard Clipper
1957 Cadillac Series 62
1962 VW Bug
1962 Dodge 880
1966 Mercury Montclair
1968 Chevy Chevelle SS
1968 Plymouth Barracuda
1977 Lincoln MKV
Lexi
Changing brake shoe linings can also effect the feel of the pedal. Clay/Lexi
