1960 Coupe Deville preservation
Started by keepat, April 07, 2023, 06:02:39 PM
Cadman-iac
  I like your idea of using a removable mount for your fire extinguisher.  That way you haven't modified the car, yet still have it easily accessible in case it's needed.
 I keep an extinguisher in all of my vehicles, and have even mounted one up under the dash. It was the only place I could hide it and still have it easy to reach, that was on a 64 Chevelle.
 Your idea is much better.
 Rick
CLC# 32373
Cadman-iac
Quote from: The Tassie Devil(le) on May 10, 2023, 08:02:32 PMThat is a very nice way of fitting the Extinguisher.
The only trouble is that if it is on the passenger side, and the seat back falls forward in a bingle, then the unit could act as a dangerous flying object within the cabin.
Thanks for showing it.
 Man the English language can be so different from one continent to another. I had to look up a "bingle" to understand what you were talking about. I've never heard that term before.
 Learned a new word today. Gotta try it out now on my wife and see if she gets it.
  Rick
CLC# 32373
David Greenburg
Great idea to have it removable; since the good ones aren't cheap, I'm always concerned about someone swiping mine at a large show.
David Greenburg
'60 Eldorado Seville
'61 Fleetwood Sixty Special
keepat
Quote from: Cadman-iac on May 12, 2023, 01:12:19 PMI like your idea of using a removable mount for your fire extinguisher.  That way you haven't modified the car, yet still have it easily accessible in case it's needed.
 Rick
I had a small electrical fire on a 66 unrestored GTO but fortunately I had a fire extinguisher. But I did not have a fire extinguisher in the rest of my cars so I have since added them using the same seat mount as I did in the Cadillac.
Cadman-iac
How did you bend the metal for your mount? It looks like a professional job.
  Rick
CLC# 32373
G'day Rick,
If you look closely, the mount is in two parts.   A length of Channel, and a flat piece.
keepat
Quote from: Cadman-iac on May 13, 2023, 09:25:57 PMHow did you bend the metal for your mount? It looks like a professional job.
  Rick
The one for the Cadillac I bent in a break, and the one on the blue seat is for a 72 Trans Am that I welded.
Cadman-iac
   How thick is the aluminum that you used? It looks like it's at least 1/8" thick, or even 3/16", but hard to tell in the pictures.
 Rick
CLC# 32373
keepat
Quote from: Cadman-iac on May 13, 2023, 10:44:22 PMHow thick is the aluminum that you used? It looks like it's at least 1/8" thick, or even 3/16", but hard to tell in the pictures.
 Rick
1/8"
I should have looked closer.
The piece that I thought was attached to the channel piece is actually the vinyl piece stuck to the bracket to protect the upholstery.
I have chastised myself severely.
keepat
Did few spray outs to find the best match for the original factory applied dark blue engine paint. Below are pictures showing the 5 brand I used. IMO Bill Hirsch was the clear winner.
Pat532EC3D0-07E3-432C-B4AD-9C7C1FE556A1.jpeg07CC41EE-7EDE-4AA1-8D28-C47E58441F5D.jpegBAF46241-55D9-4140-90EC-883812366C50.jpegDDACD1AF-A3E3-49D7-97F5-85A91B8B1A9D.jpeg450DD8F6-56EC-4AF8-9110-54E64584627E.jpeg
