I have just ordered a full set of glass for my 37 Series 75. Bob's Classic Auto Glass has all of the glass and rubber except the rear quarter windows (He has the vent rubber).
Does anyone have any idea what I should do for the rear quarter rubber seals? Is there a roll material or something that will work. The existing rubber is original and is pretty well cracked and rotted.
Thanks for the pointers.
Chad B.
Have you tried Steele rubber ?
Have not. Well, actually I got new brake and clutch pads from them.... I will give it a try.
You should also call "Rubber the right way"
They have other rubber also that Steele does not make And RTRW also sells cheaper most of the time than Steele rubber direct.
thanks
