Hi everyone,
Driving my 1968 Eldorado today, I had the climate control set to VENT.
All of a sudden (in heavy traffic on I-15 through Las Vegas), car stalls, I restart it, smoke comes out, bad noises.... get it off the road... more smoke and bad noises (I had to keep my foot on the gas to keep it from stalling... nasty!)
Turns out... the A/C compressor clutch has seized. I open the hood and the belts are shredded (two-groove pulley, so two belts).
Not the compressor! I can still turn the front plate of the compressor by hand, quite easily. Heck it wasn't even engaged when it went out. So it's just the clutch.
What the heck could have happened here?
I think the compressor is about a year-old reman from RockAuto. Maybe 3K miles on it.
Anybody seen this happen? And successfully just replaced the clutch?
I am contemplating buying another reman compressor and swapping clutches with the one on the car. I could avoid dumping the refrigerant and recharging if I swap the clutches instead of the compressors.
Or should I replace the compressor?
Any ideas from the Forum?
Mika
Sounds like the double row roller bearing that the pulley rolls on is seized.
This can be replaced without removing the compressor, or losing the gas, but you will need the proper tool for removing the driven plate which is attached to the compressor shaft, which is what you were turning.
If you are going to do it yourself, then you will need some circlip pliers, to remove the circlip that retains the inner part of the bearing, a deep either 1/2" or 9/16" socket to remove the retaining bolt, the puller, and another puller to remove both the pulley, and the bearing.
The Shop Manual describes how to accomplish the task.
Thanks, yeah.... I think I have the puller. Never used it before. I did do a clutch on a ... R4.. once on a '93 Fleetwood. Not sure about the pliers.
I am mostly curious whether this kind of failure "does happen" or it's indicative of something else that might be wrong. My intuition says no, since it wasn't even engaged... the compressor ought to be fine. But I've never seen this particular failure before.
It's a pain to park without power steering but it actually feels almost better on the freeway...
If the '68 472 uses the the same external parts as the '72 500, then you can get belts to simply run the power steering pump on its' own.
On my 500 I run one belt from the crank to the power steering pump, and the front one via the AC Compressor, as when the compressor was changed whilst in USA, it was replaced with a single-pulley pump. Both are tensioned via the Power Steering pump.
As I am running an HEI Distributor, I left the belts the way they were because the rear belt would rub on the distributor cap.
I bought a low mile used unmolested compressor for my 70. Upon installation the bearing was noisy. Had a good bearing in the compressor I took off. I got the tool kit from O'Reilly loan a tool program and swapped the works out in about half an hour. It's pretty easy to do but the removal and installation tools are a must. Compressor stayed in the car and no loss of refrigerant.
Quote from: Dan LeBlanc on November 04, 2017, 08:22:58 AM
..... I got the tool kit from O'Reilly loan a tool program and swapped the works out in about half an hour. ......
I suppose one of the good reasons for living in USA and Canada. .... But, I would still live here.
Quote from: mikanystrom
I have had a few clutch bearings go out; spares and tools are in stock
here. As I remember A6 and R4 use different tools, but the same
bearing. My belt arrangement allows everything else to work without
compressor belt(s).
Bearings without good grease will soon fail. A sealed bearing can't be
regreased, and decades old grease dries up, so this failure can only be
avoided by adding the bearing replacement to regular maintenance.
Bruce Roe
A couple of notes:
You can use 48" belts to bypass the compressor and give you power steering until you can get it repaired.
Undo the mounts that hold the compressor to the engine. I think its 3 bolts in the back and 2 up front. This way you can lift it up by the front; easier to get at the retaining nuts in the front of the clutch. You do Not have to undo the refrigerant lines as noted earlier.
You can SOMETIMES get a clutch & pulley off of fleabay, but most that I see are single groove. The A6 double groove went through 73 (at least part way thru 73).
If its more than a year old, then Rockauto probably won't warranty it. You can also get the entire compressor with double groove pulley from amazon with free 2 day shipping if you are a Prime customer. The price fluctuates. Right now about $245. I'm not sure what rockAuto's is. I'd buy one for a spare but then it likely sit for years and there will be no warranty on it!
Ahhh so I did this the... easy(????) way...
since it's a double groove compressor, nobody seems to carry just the clutch. I guess I could have just replaced the bearing?
Since I have all the equipment, and a big 30-lb tank of R134a sitting around, I just replaced the whole compressor. Autozone, $159... hope it holds up for a while.
The hardest part was tensioning the stupid belt on the even stupider AIR pump! HOW are you supposed to loosen that inside bolt with the belt on?
And AutoZone had only a single 59 1/2 inch belt and screwed up ordering another one so I only have one belt for now. Well, no matter, I don't need the A/C in the winter, and the car is going to San Jose for a V/P transmission next week. Then I will finally get to install Bruce's controller!
$159 for the whole compressor at autozone? That's pretty good!
What is a V/P transmission? You have an ElDorado, so it may not have meaning WRT my RWD DeVille, But I'm still trying to get a 4sp transmission fittedto this car, it would save a lot of fuel and educe engine wear.
The AIR pump. I had to go under to car to do anything with that, so off it went. If you can find the 1970 pulleys you can go to three belts.
Quote from: cadillacmike68
Every automatic big block 65-67 Olds, Buick, or Cad was built with a V/P or
Switch Pitch transmission. The torque converter may be switched electrically
to performance or economy mode, in effect a 6 speed trans. It can slightly
increase mileage by slipping less, and even allow a somewhat lower number
axle ratio for lower rpm and more savings. In the performance mode it can
considerably improve the response of the car, and smooth trans operation.
Any TH400/TH425 car can be converted to a switch pitch trans, which is a
direct bolt in and just as strong as the original. There is long list of issues with
trying to convert a TH400 car to a 4 speed. In time I got tired of regular 3
speeds, and eventually converted all 5 of my cars to switch pitch. Bruce Roe
Bruce, if they were all built with a V/P (variable pitch??) Trans, then why do you have to convert the trans? Might be time for a new topic, we don't hijack this thread.
Quote from: cadillacmike68Bruce, if they were all built with a V/P (variable pitch??)
trans, then why do you have to convert the trans?
Wasn't me that asked about V/P and 4 speeds. I had to convert my
cars, because they weren't 65-67 models. Bruce
So I take it that 1967s had V/P transmissions but 1968s did not? Well, that's not good news to me.
I don't mind you guys hijacking my thread. Yes, $159 for the compressor at AutoZone. A new one could be had (at AutoZone) for... I don't remember... $750 or $900. Well I have replaced so many of these now that if it goes out again I know what to do, takes me about an hour with recharge and all. Heck even flushing out the system isn't that hard...never had an A6 come to pieces on me though, usually it's something stupid, like problems with the clutch.
134a with a cycling clutch will do that.
"cycling clutch"...!! Newfangled silliness!
Quote from: mikanystrom on December 09, 2017, 02:17:45 PM
It was supposed to be a fuel saving "feature" ::)
I have learned to buy NEW or a high quality rebuild. Since this rebuild is only a year old...speaks volumes of its quality. Save yourself and just replace the whole assembly with higher quality.
I wonder how god the 4 seasons ones are. I have a 4 seasons rebuild in my 1996 Fleetwood, and its been good for a few years. I use that car a lot more than my 1968.
Quote from: cadillacmike68 on December 09, 2017, 09:13:26 PM
I've never had a problem with their products. I've been using their products in all my old cars. The '47 has three of their motors in there since I converted to 12V. They were the only company that had the identical replacement as far as size, shaft diameter, and rotation to match the original 6V motors. Have one under the dash and two in the underseat heaters. Their catalog is quite impressive and highly detailed...
http://www.4s.com/en/products/motors/
I would just say, I would NEVER go to the labor and expense to
replace a perfectly good compressor, open up and recharge a
refrigeration system, if all it need was to put a bearing in the
clutch.
New stuff, it has caused me so many quality problems, I avoid
it in favor of good used original whenever possible. Bruce Roe
FWIW I just timed the removal and replacement of the clutch, pulley and bearing replacement at just under an hour, working slowly with the correct factory tools. That is with the compressor unbolted from the intake but left connected to the refrigerant lines. Although in the past I had just about never seen a pulley bearing go out, it seems to occur with a greater frequency on the current run of rebuilds. Apparently they are reluctant to replace the $30.00 bearing and are re using old and possibly failing ones.
I am currently working up a stock of pulley/bearing/clutch assemblies for my future use so when failure occurs I will be ready.
Quote from: bcroe on December 09, 2017, 10:16:47 PM
clutch.
Can't deny it sounds a bit crazy, but I think it really only took me an hour as well, and I don't have all the pulley tools (only about half of them)...
Yes, if the rest of the compressor and its internals are fine, then undo the belts remove it from the intake and use the pullers to take the old clutch and pulleys out and replace whats bad. Absolutely no sense in breaking the lines.
Of course you need to be able to find the correct dual groove parts.....
Mike,
For some reason a couple of years ago when I wanted to buy a clutch/pulley assembly I found them hard to find. It prompted a project where I collected a few single and double belt pulleys and bought some bearings. I have a stock for what ever I might need in the foreseeable future. I think it is because at one time when a pulley needed a bearing they just discarded them and used another, leading to the shortage.
Quote from: cadillacmike68 on December 10, 2017, 08:40:17 PM
Yeah that's really the problem. My autozone (right down the street) carries the compressor but not the parts! I was actually thinking of taking the new compressor apart to swap pulleys and bearings as you suggest and keeping the rest of it but decided to swap and get the core charge back instead....
